Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
175K911's Avatar
What do you use to cut flares off with?
Getting ready to cut the rear Carrera flares off my '86 in preparation for hanging my 930 rear flares. I can use my cutoff wheel with 4" disc, or my 3" cutoff tool, or my pneumatic jig saw. Normally I'd use a cutoff wheel but that makes it tough to cut a semicircular arc, or am I wrong?
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 08-23-2012, 08:35 AM
Bird. It's the word...
Fishcop's Avatar
For straight lines a 1mm cut-off wheel; for curves the air saw is great, the gap created by both is perfect for using a Mig/Tig later to rejoin. I've also used an air "nibbler" and shears if a wider cut is acceptable, they leave a much nicer working edge but use up 3mm making their cuts.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-23-2012, 04:30 PM
