Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
How long before applying graphics on new paint
We are almost at the paint stage in my backdate 73 RSR project. I have Carrera vinyl graphics to apply. How long should I wait before applying them on new paint?
Old 04-25-2015, 04:51 PM
dkbautosports.com
962porsche's Avatar
you should wait until you can press you finger nail in the surface and it does not leave a nail mark .
if it leaves a mark the finish is still out gassing it's solvent's .
this will give bad adhesion of the vinyl it could lead to the vinyl delaminating or bubbles in the vinyl .
Old 04-25-2015, 05:13 PM
Thanks for the quick reply. Again 962 to the rescue. Is it normally about 48 hours or a week. Or ???
Old 04-25-2015, 05:31 PM
dkbautosports.com
962porsche's Avatar
it depends on the cars panel temperature how much material (coats of paint) are applied and type of material .
most cases at about 70 degrees your looking at 48 hours .
I always give it the finger nail test .
in my area of the country we may have day time temps of 70 but at night the temp will drop down to 50 degrees .
this will add curing time to a finish .
it's also the temp of the panels not the air temp you have to go by .
the air temp maybe 70 degrees but the cars panel temps could be higher or lower then the air temp .
Old 04-25-2015, 08:13 PM
Thanks again. Good info.
Old 04-26-2015, 11:05 AM
