Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
356 with automatic trans ?
I know it sounds aweful, but I want to put an automatic transmission in a 356 c conv. It'll be a present!
Has anyone every seen anything like that or knows how to do it?
I am thankful for any tips or hints where I can find a very good 356 C conv. for a better without transmition or engine !
Thx everyone!
Please contact me at LADIRK@GMX.NET
1991 Porsche 964 C2 - Ohm!
1980 Porsche 911SC Targa - for sale now
2006 Husqvarna 610SM - my trick horse
1949 Pontiac Chieftain
2005 Cannondale Ironman
Old 03-28-2007, 03:57 PM
check and see how Intermecanica up in Vancouver do it,
I know they do some with automatics,
you will need to put IRS VW rear trailing arms on it which might make your rear track a little wider.
I would use a VW motor and autotrans out of a Squareback,
Change the motor tin to the bug stuff,
If you want to use a 356 motor you will need to make your own flex plate that holds the torque converter.
In the big picture its not a hard thing to do,
the only "hachet" work will be the pivots for the IRS trailing arms, and maybe some clearancing in the back seat area as the auto tranny does not have the same shape....
If you do it post some pics, and try not to do things that make it impossible to put it back stock....
Dave
looking for information about old VW Coach built based sports cars, or photos and stories from the past ,
At one time many of these got confused as "Porsche prototypes" including the one restored at Hill and Vaughn in Santa Monica
Old 03-28-2007, 04:30 PM
Here is some info on putting a full auto in a bug. Not the same because of the frame horns but FYI.
Click on RyanB's page for better pics
http://www.shoptalkforums.com/viewtopic.php?t=102293
Old 04-09-2007, 10:02 AM
Since the sportomatic was mated to the early 6 in place of a 901 box, and the 901 box was also used in the 912, mated to the 4 which was nearly identical to the 356SC motor, "it stands to reason" that a sportomatic + 4 might be configured for a 356. The big issues would be a) are extensive chassis modifications needed to fit the sporto into the 356? (inc suspension tuning to address weight dist), b) will the power losses + added weight introduced by the sporto make the resulting perf envelope unsatisfactory, or even unsafe? There are no doubt many minor issues as well.
It seems that given what has been created with outlaws, just about anything is possible... add elect windows and ac and call it an in-law.
Old 04-09-2007, 03:42 PM
Sportomatic is not a real automatic trans,
its more like an electric clutch with a torgue converter,
you still need to shift gears to really drive it,
yes it will start in high gear, but it just stays in high and the torgue converter works harder to get it moving ,
A VW squaeback has a real 3 speed automatic,
Dave
Old 04-09-2007, 10:25 PM
of course, technically, you are correct Dave. however, it doesn't have a clutch pedal to actuate shifts & you can place it in D & drive away - so to an unsophisticated user, it may be thought of as "automatic" - otherwise, why did Porsche build it?
Old 04-11-2007, 07:45 PM
the sportomatic has an automatic "clutch" but does not shift gears by itself, you need to shift or leave it in one gear and let the torque converter do it ,
A true automatic shifts from gear to gear internally
why did Porsche build it , beats me
lazy drivers ?
Dave
PS......VW had the same set-up called Autostick,
and even had it in the early 60s called Saxomatic
Old 04-11-2007, 10:05 PM
thanks Dave, I finally understand what a true automatic is.
Old 04-13-2007, 05:04 PM
