Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Volvo_1800 (guest)
Guest
Posts: n/a
I have the Type 1 VDO Kienzle clock that I let sit in my unused car for a few years. As the battery drained down, it lost the power to open the contacts. The low-temp solder fuse melted as designed, but not enough to completely open the circuit. You can see this in the attached photo. Also, you can see that the electro-magnet coil overheated from the closed circuit, and the insulation melted, allowing a short circuit on the coil. So I need to remove and replace this wire with new electro-magnet coil wire. Does anyone know the gauge of this wire, and the number of revolutions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-27-2013, 02:11 PM
Nick at Pelican Parts's Avatar
I am not 100% sure on the specifics.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
