Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Home of the Whopper
C rotor minimum thickness specs?
Anybody know what the minimum rotor thicknesses are for a C coupe, front and rear. Not having any luck finding this information.
Also cant search on the 356 registry. Guess that is a members only feature?
Thanks!!
BK
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 09-08-2014, 05:19 AM
id10t's Avatar
From my archive of 356talk emails before they went all forum-y
The shop manual says min thickness of front discs is 9.8mm [.386"]; rears
9.3mm [.366"]. Run-out of fronts .2mm [.008"]; rear .3mm [.012"]. Most
brake drums and discs get turned when it isn't necessary. Some roughness is
acceptable.
Old 09-08-2014, 06:22 AM
Home of the Whopper
Thank you! Looks like I need to order some rotors!
Old 09-08-2014, 07:42 AM
id10t's Avatar
I'd also recommend finding a copy of Elfrinks Tech Manual for the 356
Old 09-08-2014, 08:28 AM
Home of the Whopper
Yea, got the Elfrinks but couldnt find the data on the wear limit on C rotors. Did I miss something?
Old 09-08-2014, 11:29 AM
