hpmad's Avatar
Need help diagnostic shift leaver problem
Hello,
1980 SC Targa, 120K
During a 200Km drive, I lost my 5th, rear and 3rd gear!
No grinding noises, no weired sound, I just can not shift into them as if the shift lever was blocked from going there...
Any clue what might be wrong and where to "dig" to find the problem and fix it?
1st, 2nd and 4th work with no issues althrough I need to change the clutch cable...
Thank you
Cyrille
Old 06-19-2018, 11:58 AM
Did the shift coupler slip out of alignment?
Do a search for "shift coupler adjustment" or look in the 101 projects book if you have it.
_______________________________
1982 911 SC 240,000mi and counting
Old 06-19-2018, 12:13 PM
ROW '78 911 Targa
timmy2's Avatar
Bushing in shift coupler fall apart?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-19-2018, 12:38 PM
Senior Member
Jdub's Avatar
See also this link that shows how the internal shift fork, when loose, can cause issues. Drain oil first, have new gasket in hand.
'78 Targa in Minerva Blue
Old 06-19-2018, 12:40 PM
hpmad's Avatar
Hello,
Well I pulled things appart and the bushing that holds the link is completely destroyed (in 2 parts)!
I am talking about this bushing:
https://cdn4.pelicanparts.com/techarticles/101_Projects_Porsche_911/37-Shifting_Improvements/images_small/Pic5.JPG
So, I have ordered replacement for said bushing and the "cup" and will see how much that helps...
If not enough, then I will look at changing the back coupling.
Thanks for the pointers,
Cyrille
Old 06-20-2018, 03:55 AM
hpmad's Avatar
Hello,
I changed the bushing and ball cup under the gear lever and all is now well!
Thanks for the quick diagnostic.
Cyrille
Old 06-21-2018, 08:04 AM
