Euro-premuffler / O2 Sensor Question
I am in the process of installing a Euro-premuffler and noticed that the fitting for the O2 sensor is near the point where the premuffler meets the muffler. This is more than a foot away from the current O2 sensor fitting on my stock cat. I have not looked at how much excess wire I have on the O2 sensor but am sure that it will not reach.
For those of you that have installed a Euro-premuffler, how did you deal with this ?
Old 02-26-2003, 10:29 AM
I had the bung installed in pretty much the same location as was stock for the cat. Doing this, however, had the 02 sensor "read" one set of 3 cylinders more than the other three...by virtue of the upstream side construction of the premuffler ( two pipes, one for each bank of cylinders comes together at this point, and the sensor read the "top" pipe). Not a biggie.
Got the bung from Bruce Anderson's pal, Jerry Woods...had it welded locally.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-26-2003, 10:43 AM
KTL KTL is offline
Schleprock
KTL's Avatar
There's a good bit of extra wire in there Ron.
You just have to go in the engine bay and release the wire from a couple of places.
I also moved the rubber grommet from the middle of the O2 wire to the end. Just use a sharp razor blade to cut a radial slit into the grommet and be careful not to cut the wire sheathing. I decided to not use the wire extension that comes with a B&B header kit and do the above "lengthening" instead. Here's a picture:
Also, if you can find a source for the male-female elec. connectors, you can make your own harness extension. Some fellas on here have done this. It was mentioned in a SSI exhaust upgrade topic
Kevin L
'86 Carrera "Larry"
Old 02-26-2003, 10:49 AM
Not Quite Banned
Thomas Owen's Avatar
On my Euro the O2 mount is before the muffler, just like the cat. Where did you get the pre-muffler? (Mine is a stainless FabSpeed).
Thomas Owen
1972 911T
1972 911S
Old 02-26-2003, 02:49 PM
Wavey's Avatar
So is mine (it's a Fabspeed).
Old 02-26-2003, 03:19 PM
Here is a picture of the pre-muffler. The O2 sensor mounts at the end near the exit to the muffler.
Old 02-26-2003, 08:15 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Relocating the grommet on the O2 wire should work like I did mine Ron. You can see in the picture how much extra wire you end up with after moving the grommet. That's why I had to secure it to the bumper extension support tube with a zip strip.
Not the fanciest solution, but it's better than letting the wire flop around near the hot exhaust piping.
Kevin L
'86 Carrera "Larry"
Old 02-26-2003, 09:39 PM
Ron:
What's your part number for the Euro premuffler...I've come across about 4-6 different versions...some with 911 prefix and others with 930...all with different 00, 01, 02 suffixes for revisions.
Also ( anyone?)...does anyone know the differences among these?
---Wil Ferch
Wil Ferch
Old 02-27-2003, 05:40 AM
Rick Lee's Avatar
So what's the performance difference between a Fabspeed Euro pre-muffler and a regular old cat by-pass? Cosmetic difference is obvious. But how much more ooopmh does the Fabspeed give you?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-27-2003, 06:16 AM
Anderson says cat bypass is a "maybe" thing with regard to hp increase...maybe even a loss.
Porsche pre-muffler ( he says) adds about 4-6 hp..pretty well corraborated by various people's dyno tests.
--Wil Ferch
Wil Ferch
Old 02-27-2003, 06:32 AM
It'll be legen-waitforit
stealthn's Avatar
The Fabspeed one I am looking at has the hole only off one back of cylinders, but it's closes to the HE not the muffler.
Here's their picture.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 02-27-2003, 07:09 AM
That's how I drilled mine ( Porsche premuffler). Would also be better in this location if I needed to comply with an emissions station "visual" check... it mimics stock location,( pre-cat)...
---Wil Ferch
Wil Ferch
Old 02-27-2003, 08:01 AM
Bump:
Ron/others?....part numbers? ( previous post of mine)..
Would like to know the differences among various P-car part numbers for premufflers.
---Wil Ferch
Wil Ferch
Old 02-28-2003, 09:03 AM
