Euro-premuffler / O2 Sensor Question
I am in the process of installing a Euro-premuffler and noticed that the fitting for the O2 sensor is near the point where the premuffler meets the muffler. This is more than a foot away from the current O2 sensor fitting on my stock cat. I have not looked at how much excess wire I have on the O2 sensor but am sure that it will not reach.
For those of you that have installed a Euro-premuffler, how did you deal with this ? |
I had the bung installed in pretty much the same location as was stock for the cat. Doing this, however, had the 02 sensor "read" one set of 3 cylinders more than the other three...by virtue of the upstream side construction of the premuffler ( two pipes, one for each bank of cylinders comes together at this point, and the sensor read the "top" pipe). Not a biggie.
Got the bung from Bruce Anderson's pal, Jerry Woods...had it welded locally. ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Schleprock
There's a good bit of extra wire in there Ron.
You just have to go in the engine bay and release the wire from a couple of places. I also moved the rubber grommet from the middle of the O2 wire to the end. Just use a sharp razor blade to cut a radial slit into the grommet and be careful not to cut the wire sheathing. I decided to not use the wire extension that comes with a B&B header kit and do the above "lengthening" instead. Here's a picture: ![]() Also, if you can find a source for the male-female elec. connectors, you can make your own harness extension. Some fellas on here have done this. It was mentioned in a SSI exhaust upgrade topic
Kevin L '86 Carrera "Larry" |
Not Quite Banned
On my Euro the O2 mount is before the muffler, just like the cat. Where did you get the pre-muffler? (Mine is a stainless FabSpeed).
Thomas Owen 1972 911T 1972 911S Last edited by Thomas Owen; 02-26-2003 at 03:48 PM.. |
Here is a picture of the pre-muffler. The O2 sensor mounts at the end near the exit to the muffler.
Schleprock
Relocating the grommet on the O2 wire should work like I did mine Ron. You can see in the picture how much extra wire you end up with after moving the grommet. That's why I had to secure it to the bumper extension support tube with a zip strip.
Not the fanciest solution, but it's better than letting the wire flop around near the hot exhaust piping.
Ron:
What's your part number for the Euro premuffler...I've come across about 4-6 different versions...some with 911 prefix and others with 930...all with different 00, 01, 02 suffixes for revisions. Also ( anyone?)...does anyone know the differences among these? ---Wil Ferch
So what's the performance difference between a Fabspeed Euro pre-muffler and a regular old cat by-pass? Cosmetic difference is obvious. But how much more ooopmh does the Fabspeed give you?
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Anderson says cat bypass is a "maybe" thing with regard to hp increase...maybe even a loss.
Porsche pre-muffler ( he says) adds about 4-6 hp..pretty well corraborated by various people's dyno tests. --Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-27-2003 at 06:56 AM.. |
It'll be legen-waitforit
The Fabspeed one I am looking at has the hole only off one back of cylinders, but it's closes to the HE not the muffler.
Here's their picture.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
That's how I drilled mine ( Porsche premuffler). Would also be better in this location if I needed to comply with an emissions station "visual" check... it mimics stock location,( pre-cat)...
---Wil Ferch
Bump:
Ron/others?....part numbers? ( previous post of mine).. Would like to know the differences among various P-car part numbers for premufflers. ---Wil Ferch
