LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
AndrewCologne's Avatar
Thoughts on replacing 911 SC ECU with Raspberry solution
Hello everybody
and especially all Porsche lambda, raspberry loving and ... coding cracks. :-)
These days I was thinking of enhancing the lambda control by using a "wideband" AFR gauges "0-5v" output possibilities.
All I would need is a unit to tell via 12v PWM output the Frequency valve to operate at specific PWM rates, means duty cycles.
This unit would get the input via the 15c temp switch, the 35c temp switch, the micro- and the throttle angle switches at the throttle body and ... the 0-5v voltage signal of the AFR gauge system.
And so .. the closest way would be to set up a Raspberry Pi for this, as it comes with GPIOs (including PWM pin!).
What do you mean?
Any thoughts, infos, cents on this? :-)
PS: I already checked this thread but seems to handle WUR as subject only:
Let's discuss digital WURs and replacing K-Jet Lambda
EDIT: Its getting hot:
https://tutorials-raspberrypi.de/raspberry-pi-gpio-erklaerung-beginner-programmierung-lernen/
English sources are very welcome as well :-)
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 07-03-2018, 04:08 AM
You could probably use a Pi Zero for what you are looking at doing.
In fact... you could probably use an Arduino.
Keep in mind that there are a few other things that need to be addressed beyond just the I/O signals being transmitted to various sensors.
1987 Porsche 911 Carrera Coupe
Old 07-03-2018, 06:32 AM
Jameel's Avatar
Subscribed. I'm always wondering what I'll do when/if my stuff under the passenger seat dies.
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 07-03-2018, 06:44 AM
I would rather be driving
jpnovak's Avatar
Just rip it all out and go full EFI. Benefits everywhere.
Old 07-03-2018, 06:46 AM
Jameel's Avatar
It has crossed my mind, that's for sure. $$$ though. Just coming off a full engine rebuild, so the wallet's a bit light.
3.0 rebuilt by me
Old 07-03-2018, 07:04 AM
jpnovak's Avatar
Search for old threads about simplifying the CIS. You don't need the frequency valve. It was a late CIS bandaid for emissions and used to compensate for aging/worn components to keep the mixture in compliance. You can setup and tune CIS without it - but I wouldn't bother.
Old 07-03-2018, 07:18 AM
wreckah's Avatar
i concur.
no point in investing in upgrading an annoying addon on addon system invented by porsche to make life difficult and complex.
wait a little while longer, save some pennies, and once your CIS gives up or starts failing (it will), go bitzracing kit. 2.000 USD and you rip all that old **** out. I'm almost 2 years with EFI now and there's no way i'll ever go back to CIS.
before: '69 Porsche 911T bahama yellow
now: 1981 911 SC Targa winered
Old 07-03-2018, 07:23 AM
WP0ZZZ's Avatar
It would be a fun project but it would be even more fun to have full control of injection and ignition!
Old 07-03-2018, 08:00 AM
@jpnovak
There have been a dozen threads where people asked how to remove the freq valve but .. as the Lambda based 930/16 engine comes with a diff. fuel distributor you can't just compensate the resulting leaning out of the system when the freq valve has been removed as the pressure of the FD's low chambers would simply be screwed up.
As the original ECU is very simple and based on a narrowband O2 Sensor it comes with some slightly noticeable disadvantages like i.E. a slight hunting idle.
This is due to the very inaccurate narrowband 0-1v voltage jumps provided to the ECU.
But thats just one issue.
Also in Germany this inaccurate and prehistoric type of 3-way lambda control won't let pass the 930/16 based cars to obtain a "green sticker" permission to drive within cities where only cars with green stickers are allowed to drive.
With a very accurate lambda and therefore AFR control incl. a more modern type of catalysator it could be that the emissions will be within the "green sticker" specs.
Old 07-03-2018, 08:22 AM
3rd_gear_Ted's Avatar
"As the original ECU is very simple and based on a narrowband O2 Sensor"
This makes the village idiot (me) have dumb question;
If the control loop for the freq. valve is based on input from the O2 sensor, what happens to the freq valve output signal if you don't have an active O2 sensor??
1980 911 - Metzger 3.6L
2016 Cayman S
Old 07-03-2018, 08:57 AM
Still here
pmax's Avatar
It goes open loop. 50% duty cycle.
Old 07-03-2018, 11:55 AM
Still here
pmax's Avatar
I think of the FV system as an adjustable fuel pressure regulator, electronically controlled using a simple PVM signal. It can used for more than just emissions with an updated controller such as the one Andrew is looking at. Adding more sensors is possible as well.
Last I checked, these hobby ECU's were relatively cheap and yes, this is on my project list someday !
Old 07-03-2018, 12:03 PM
Hmmmm.
So I would need
- a temp sensor or even using the existing 15c and 35c temp switches
- a narrowband- or even a Bosch LSU 4.9 wideband oxygene sensor
- a Raspberry Pi
- an A/D and D/A converter
And a code which reads the input voltage of the sensor where a controlled 12v PWM duty cycle would be provided to the frequency valve brining/keeping the AFR to stoich.
Beside this, if the the Throttle switch is beyond 30% or/and the temp sensor provides below 15c the duty cycle provided to the FV would be 65%. And if the temp is below 35c, then when passing the 5° angle on hitting the gas pedal the duty cycle to the FV would be 75% for 3 Secs.
So using C or C++ there would be an if/then Loop where all the input from the switches and sensors would be read out which affects the PWM voltage duty cycle provided to the FV.
So ... someone has skills on how to attach an A/D converter to the Raspberry Pi which provides the sensor voltage and the position of the switches at the throttle body?
And also attaching a D/A converter providing the correct 12v PWM based duty cycle to the FV.
Old 07-04-2018, 03:42 PM
WP0ZZZ's Avatar
Running a Linux system for such a simple task seems a bit of an overkill to me. A Raspberry Pi boots quickly but it still needs a few seconds.
If the temp switches are of the on/off type you can directly use the GPIO pins on the RPi. If they provide a variable voltage you need an A/D converter. I don't have experience using them on the RPi but it seems like an easy and cheap thing to do:
https://learn.adafruit.com/raspberry-pi-analog-to-digital-converters/overview
Old 07-04-2018, 05:39 PM
Still here
pmax's Avatar
The Arduino hobbyist ecosystem looks like it has off the shelf boards for all these components above.
Microcontrollers
Digital Pins: How the pins work and what it means for them to be configured as inputs or outputs.
Analog Input Pins: Details about the analog-to-digital conversion and other uses of the pins.
PWM: How the analogWrite() function simulates an analog output using pulse-width modulation.
Memory: The various types of memory available on the Arduino board.
https://www.arduino.cc/en/Tutorial/Foundations
Old 07-04-2018, 06:02 PM
Yes, Arduino seems a nice way to go
https://forum.arduino.cc/index.php?topic=448191.0
Old 07-11-2018, 02:02 AM
Chain fence eating turbo
Have you read the 'FrankenCIS' thread?
It's the same journey as you are wanting to do to a degree.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-11-2018, 06:15 AM
El Duderino
tirwin's Avatar
Originally Posted by AndrewCologne View Post
Hello everybody
What do you mean?
Andrew,
I've been busy lately and have been meaning to reply.
Here are my thoughts. This is a subject I've been thinking quite a bit about.
First, the K-Jet w/ Lambda box. Yes, it's 1980's tech. But the thing is you really don't hear much about these boxes failing. Not that it doesn't happen, of course, but you really don't hear much about them being a common problem source.
What you're talking about could certainly be done. I think there are a few issues:
1) I'm not sure the Raspberry pi/Arduino is the right platform. You might have better luck with using a Megasquirt ECU.
2) It would take some time & testing to account for the various states to reverse engineer the Bosch box. Take a look at this post by javadog. This gives a nice summary of the various states (or conditions) you'd have to account for.
3) I tend to agree with others that if you were going to go this route, it would be better to go with something like Megasquirt.
If you look at engine theory, you will come across the term BMEP (Brake Mean Effective Pressure). BMEP is the equivalent average pressure acting on the piston during the entire volume change in the cylinder. It turns out BMEP is a great way to compare most internal combustion engines, regardless of displacement.
When BMEP increases for a given engine, it is either because the engine was a) able to extract more power or b) the engine was able to draw more air (VE, or volumetric efficiency increase).
So why am I saying this?
If you play with the math, you can see that -- at least on paper -- there is latent power gain potential for most of our engines. The question is how much power can be gained by extracting more power and how much can be gained by increasing VE and at what expense?
The reason that people say turbocharging an engine is the cheapest HP gains is because a turbocharger dramatically increases volumetric efficiency. Now whether a given engine can handle turbocharging without blowing the motor is another question.
Take a stock SC 3.0 motor and convert it to EFI. You can do things like change the intake, cams, flow the heads, change the exhaust, etc to help the engine breathe. Those things will affect VE. The change in ignition and fuel delivery will allow precise control of the fuel delivery and spark timing which will help extract more power. Of course, you can increase displacement and compression ratio, but that is yet another cost increase. (If you HAVE to do an engine rebuild, that's one thing... but if you don't have to...)
The problem, at least as I see it, with an EFI conversion is that it isn't a simple swap out of CIS->EFI to get real gains. You'd probably want to change cams, intake, exhaust, etc. which adds additional cost on top of the EFI conversion itself. Now maybe you can do these things as incremental steps so financially you don't have to do it all at once, but my point is these are the kinds of things you want to eventually do if you want to reap the rewards so eventually most people will care about the total cost involved. (PS, some people claim that the domes shape of CIS piston are not ideal for EFI either.) The costs begin to add up quickly and there are many variables that affect the potential for real HP gains which makes it difficult to arrive at a meaningful cost/benefit analysis.
What I've been wondering is if there is a viable intermediate step in CIS->EFI conversion -- a "partial" upgrade to CIS to get some of the easiest gains without all the expense.
In a CIS K-jet w/ Lambda system, there are a few things that affect normal operating fuel delivery:
1) warm control pressure (regulated by the WUR)
2) throttle position
3) frequency valve & narrowband O2 sensor
(I'm going to ignore the bits that affect cold start for now.)
Basically, K-Jet regulates fuel delivery based on engine load conditions. EFI does the same thing and a lot more.
I like the FrankenCIS idea because you get a wideband O2 which gives you the ability to have better data and to do data logging. You also avoid the analog nature of WUR calibration, plus you can replace the frequency valve functionality too. To get the most potential out of it though, you'd want to be able to somehow know the engine load and also control the spark. Jonny (of Classic Retrofit) mentioned that he has played around with this idea and I'd like to see the idea developed more. To me, combining the benefits of his CDI+ electronic ignition timing control, multi-spark up to 10,000 rpm and more precise fuel delivery seems like it would be possible to get enough (but certainly not all) of the gains of an EFI conversion at a much lower initial cost. It is hard for me to say.
The alternative would be to integrate the Megasquirt/FrankenCIS ECU with some other ignition system to control spark timing.
A digital replacement for the WUR (AND the AAR -- why not?) would also improve reliability and reduce some of the troubleshooting hoops we usually have to go through.
Sorry for the long-winded answer, but you asked.
These are ideas that are rumbling around in my head. I'd welcome more discussion on this.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-11-2018, 09:33 AM
Hi Tirwin,
thanks for your reply!
I have been reading many of your posts in here, i.E. the PLX wideband->narrowband issue when connecting to the original 911 sc ECU.
Im aware of all states of the ECU, means the 15c and 35c state and also in combination with the micro- and throttle switch.
My target is to keep the CIS as original as possible, means no further EFI upgrades or similair changes.
I just wanted to find a "programmable" solution for using instead of the old only electronically based original ECU. Thats why I startet this here.
To me its also difficult to unterstand why Porsche still used a WUR in a lambda and therefore ECU based CIS system where the ECU influences the fuel pressure via the frequency valve directly. The WOT acceleration feature via throttle switch where the ECU enriches the AFR mixture, makes the vacuum in the WUR therefore not needed anymore. Thats why the engineers dropped the vacuum feature and this shows the capabilities of the ECU based AFR mixture.
So as Im a bit in programming C language I thought an optimized programmed DIY ECU could be a nice option for less amount of money compared to mega squirt or similair.
Beside this – as o2 wideband sensor device I am thinking about purchasing the Innovate LC-2 lambda sensor/controller combination which also provides the narrowband simulation.
Where there only issues with the PLX narrowband output in your case or did you test the innovate LC2 narrowband output as well? Cause from some users I read that they had now problems when connecting directly to the original ECU.
Looking forward to your reply
Andrew
Old 07-20-2018, 12:07 AM
Jonny H's Avatar
We live in an age where cheap electronics and 'modules' are all over the Internet and eBay. Whilst I applaud this for hobbyists, it is leading to the assumption that electronics is 'easy' and all you have to do is connect a bunch of modules and you have a product.
The same thing happened with software in the 90s with the emergence of 'easy' languages like Visual Basic and Labview. There is nothing wrong with these languages except that they led to 'everybody' skipping the requirements and design stages and diving straight in to 'coding' - a term that grates with me on a number of levels. I have made a very good living from the mess this left behind.
Good software isn't about writing the code, it's about understanding the requirements and choosing the correct design. The same is true for electronics.
You are jumping straight into implementation by putting forward an Raspberry Pi as the solution without considering the requirements. Its a bit like asking whether a pizza is the right solution for a dinner party. It could be, but it depends who the guests are, what they like to eat and what the ingredients are.
You are focussing heavily on the central control function. This is the 'exciting bit' so it is understandable but your design will be worthless if it cannot run in its intended environment. The Internet is littered with 'it works great but I get the occasional glitch/reset/odd behaviour'. And then it died....
You need to do some homework on how electronics is protected from the harsh electrical environment.
If you think that cars run off a nice stable 12V supply then this graph might surprise you. It shows the typical transients that occur on the 12V live in a car. Sadly, many ECUs and controllers do not have any circuitry to protect against these.
That's just the 12v line. Every input will also have noise and need proper signal conditioning and isolation.
If this project is for your own entertainment then fine. If you are thinking of putting it out there then stop, do some more homework and consider contracting an EE with automotive experience.
(not wanting to piss on your chips, just experience talking)
www.classicretrofit.com
Old 07-20-2018, 04:05 AM
