3.2 hunting problem
I have had this problem for a while - when the engine is hot it won't idle properly, fluctuating between 500 rpm and up to 2k to the point where it will go below 500 rpm and stop, no problems starting it again. When cold it idles around the 850 mark very smooth. I have been through filters, injectors etc without any luck - any suggestions?
#147 of 2096
Temperature sensor ?
#147 of 2096 |
That Guy
Try cleaning out the idle stabilizer valve with brake cleaner.
Vacuum leaks are another possibility.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Is the hot idle 800 for 84-86 and 880 for 87-89? Too high hot idle brings on that effect.
I had the problem also a while back. I fixed mine by tightening the 12 bolts or replacing the gaskets on intake runners. I used a foot pound torque wrench from Harbor freight . After everything was finished, idle went right back to 800 at idle. The intake bolts just come loose over time. Some of mine were only fingerbtight when I checked them.
Brew Master
I'd start with making sure all of your vacuum lines are in good shape. Make sure your boots on the intake runners are good and clamps are tight and clean the ICV.
Member 911 Anonymous
Also as suggested check the OHMs on the CHTS. Cleaning te ICV for extra measure.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Since it's okay when the engine's cold, you probably have a vacuum leak that's being compensated for by a rich-running engine while cold. After the engine warms up & the fuel leans out, the vacuum leak is now more apparent & your idle hunts & stalls. I'd focus on finding your vacuum leak. Do a smoke test if you can't locate it after running down the usual suspects.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Thanks for all your advice, I'll give it a try on the weekend
