To all 915 experts, can you help me diagnose my issues?
My car is a 1976 911S with complete original drivetrain. everything in this car is running perfect except the 3rd and 5th gears, it will grind slightly when I put it in 3rd and its very hard to put it in 5th (no gringing when it goes into 5th, though), I need to push the shifter real hard forward to make it engage into 5th. what do you think is bad? syncro? dog teeth ring? I fit a new clutch cable and its adjusted properly, so I think the issue is internal into the transmission.
Old 07-28-2018, 10:02 AM
Just a thought, did you check the swivel in the back seat for breaking down?
Next, I would pull the side inspection plate and make sure the attached fork is firmly attached.
If it’s not, don’t try to repair, get a good one.
Bruce
Old 07-28-2018, 11:32 AM
Under the radar
Trackrash's Avatar
+1 on Bruce.
Make sure all the shifter bushings and the coupler in the rear of the tunnel are perfect.
I would also make sure the clutch is adjusted correctly.
When is the last time you changed the trans oil?
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-28-2018, 01:48 PM
Originally Posted by Trackrash View Post
+1 on Bruce.
The previous owner changed the trans fluid a year a go, I also checked it and it looks/smells new. The shifter coupling between the rear seats looks new as well and its firm and looks to be working good, as well as the front shifter.
Do you have any picture showing what I will find behind the inpsection plate? I never worked on any of the porsches transaxles and I need to carefully find my way through.
Old 07-28-2018, 03:10 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
What Bruce and Gordon said.
If the clutch is correctly adjusted, look at the shift linkage next.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-28-2018, 03:14 PM
sounds like worn syncro on 3rd... Does shifting slowly, or double clutching help?
With regard to 5th, I had a similar issue on a car a few years ago.. the guy that sold it to me said it was a 4 speed manual.. All 4 forward gears worked perfect. I got it home, and adjusted the shift linkage alignment, and had 5th gear ever since.. true.
Old 07-28-2018, 05:43 PM
When you drain the gear oil you should be able to tell if it’s regular gear oil or swepco, whatever it is it should be replaced with Kendall 80w/90 GL5.
Swepco is too slippery, the synchros need more friction, could be your issue.
Old 07-28-2018, 06:18 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Plus 1 check Coupler for slop and then try double clutching to see if that will slow/stop down 3rd and 5th
'85 Carrera Targa
PCA/POC
Old 07-28-2018, 06:41 PM
gearhead
Rubbish.
It sounds to me like 3rd gear synchro is worn AND 5th is likely a shift linkage adjustment issue.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-28-2018, 07:25 PM
Originally Posted by Matt Monson View Post
Rubbish.
Likely it’s worn synchros, but don’t discount the swepco in a 915, I’ve personally experienced it, and it presents itself with the symptoms described.
But, I’m not an expert, just limited personal experience.
Old 07-28-2018, 07:50 PM
Under the radar
Trackrash's Avatar
Yes Swepco is slippery. But once the trans is warmed up, the shifting should improve if Swepco is used.
Here is the description of the bottom plate. AND the Bible on 915s thanks to Pete Z.
How-To: Porsche 915 Transmission Repair Tutorial Part 2 - Porsche Wiki
__________________________________________________ __________________________________________________ __
Trackrash's Garage
Gordon
Old 07-29-2018, 08:34 AM
