Delete clock for volt meter
I would like to delete my clock for a volt meter. I found a plug for the hole but with shipping it works out to around US$40.00. Since I am going to cut a big hole in the plug it seems like a big waste. Has anyone come up with a cheaper solution? I am going to hit the big hardware stores to see if I can find anything. BTW, I am going to keep the clock, it works great and if I change my mind one day, I can put it back in.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
If you do a search, this has been brought up before. Some have left the clock in place and put the voltmeter elsewhere. Plus other options.
Who, What, When, Where, Why and How. |
I thought about using a bad stock clock as a housing. Fit a smaller volt meter inside the dead clock. well, I have not have time to do it yet
Fat butt 911, 1987 |
Been here a while
You can get a volt meter that plugs into your cigarette lighter....or replace your lighter with a USB port with volt meter.
I like having the cigarette lighter so I can use a tire inflator. So, I replaced my brake and seat belt warning light with a USB charger with volt meter. All of the above can be found on amazon. The longer story is that I put the gas and oil gauge over where the clock used to be, and put an AC vent on the far left.
looking for 1972 911t motor XR584, S/N 6121622 |
I mounted a volt meter below my ashtray.
Kind of Blue
I use one that fits in the cigarette outlet and even comes with a USB outlet.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
New-ish 911SC Targa Owner
Just purchased a cigarette lighter volt meter/USB charger on smile.amazon.com for $15 and free same-day delivery. What a world we live in!
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
I have to be honest, i surfed north hollywood speedo's website for about 30 minutes and almost decided to have my tacho rebuilt with an additional voltmeter added to it. Then i recalled that I'm not made of money and went with the $15 option mentioned above!
