what do you think about my compression test results?
I just made a compression test on all 6 cylinders on my '76 911S with the original 2.7 engine. It came out :
cyl. #1 145 psi
cyl. #2 130 psi
cyl. #3 150 psi
cyl. #4 150 psi
cyl. #5 150 psi
cyl. #6 150 psi
Its low on cyl. #2, but is it too low that I need to rebuild the engine? curious to hear some opinions.
Old 08-05-2018, 04:11 PM
My two cents:
- do some reading on compression tests, incl. on adding oil for a wet test
- but a leak down test is what you really need
- I'd also pull the valve covers and check for broken studs (should be obvious)
- if no broken studs, check the adjustment of the valve lash on #2 (and all the others, but #2 is the outlier.
Best of luck, John/CT
Old 08-05-2018, 04:36 PM
Are you having any issues? If not then I would just drive it and enjoy.
Rob
Old 08-05-2018, 06:48 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Leak Down,
How do the spark plugs look? #2 vs all.
'85 Carrera Targa
PCA/POC
Old 08-05-2018, 08:23 PM
