More cars than sense
1977 2.7 CIS - No spark on crank, spark on run
Trying to track down an issue on my '77 911. Car was running and driving when I bought it but has been sitting for about a year.
The car has no spark when cranking but does have spark with the key in the run position. Verified by pulling a plug lead to see the spark. When we're cranking, there is no spark at all. But when we stop cranking there is brief spark as the car briefly turns over before stopping with the key in the run position.
Seems like I've read about this issue before. Anyone have any ideas for me?
Old 08-10-2018, 04:07 PM
Could be low or no voltage getting to the CDI during cranking, maybe even a low battery.
77 911s
16 981gts
Old 08-10-2018, 04:42 PM
Battery fully charged and tested with a second battery.
Old 08-10-2018, 04:43 PM
pa911's Avatar
You should have power going to the center pin on the CDI .if it's a Bosch 3 pin
Old 08-10-2018, 05:40 PM
Car has a blue Permatune which I believe to be factory (little known fact, Porsche installed Permatune units at the factory on some cars in the 70's). Still a three wire connection. I'll check the power at crank tomorrow.
Any other ideas?
Old 08-10-2018, 05:47 PM
pa911's Avatar
Have you checked the coil?What kind of coil do you have?
Old 08-10-2018, 05:52 PM
Bosch coil. Assuming coil is good as I have spark with key in the run position.
Old 08-10-2018, 05:56 PM
maninblack,
When you are running the starter, there is a separate path for +12v to power the ignition. It is the yellow wire attached to the starter. Could yours be unplugged? It also powers the Thermo Time Switch and the Cold Start Valve.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 08-11-2018, 06:46 AM
Got it guys. Break in a wire from battery. Thanks for the help.
Old 08-11-2018, 08:42 AM
Excellent, glad it worked out for you- which cable?
Rutager West
Old 08-11-2018, 10:28 AM
