BURN-BROS's Avatar
Originally Posted by VWLoosenuts View Post
With respect that’s great info for someone that’s running factory Fuchs. Thank you. However as you can tell these wheels are far from factory! I am VERY confident in my and the manufacturers measuring of offset to fit my set up. We have measured and measured for proper fitment for my car. I CANNOT fit a 3.5” front spacing within my fenders regardless if it’s trimmed or rolled unless I over roll the fender
What Hubs are you running? Stock 76?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-12-2018, 08:41 AM
As far as I know they are stock 76 hubs.
In fairness the car started out as s 912E. Could possibly change things.
Jeremy Brooks AKA VWLOOSENUTS
***My cars are built to meet my approval, not yours!! My money, my cars, my happiness.
Old 08-12-2018, 08:59 AM
BURN-BROS's Avatar
Bill is the Resident Specialist when it comes to wheel fitment and brakes. He is posting what can normally be done when the traditional track width and the stock fender is being used.
His posts are both accurate and cautionary. It implies that something may be out of spec on your car.
Have you done an alignment prior to fitment? Do both sides measure out the same?
BTW, nice looking wheel.
Burnham Performance
Old 08-12-2018, 10:15 AM
I will report back when they are on.
Thanks for all the feed back guys it is appreciated.
With regard to fitment. My fitment preference is not for track set up. The car will be much lower in stance then typically seen on this form.
Old 08-12-2018, 11:24 AM
BURN-BROS's Avatar
Track width is the measurement from hub face to hub face. 54.06" if the drawing below is accurate. It doesn't imply competition specs.
Look forward to seeing your progress.
Burnham Performance
Old 08-12-2018, 11:41 AM
Going off the bottom left front end picture. I see the hub width of 54.06” as you’ve mentioned from that drawing?
If that’s the hub to hub width my hub width isn’t anywhere near that narrow. Mine is 56-1/8” hub face to hub face.
Both sides have a front hub to inside lip of fender is 2.75”. Everything seems true and straight
Old 08-12-2018, 02:45 PM
Bill Verburg's Avatar
I appreciate the support but track is the distance between the tire centerlines which coincides w/ the wheel center lines
it differs from hub to hub by 2x the wheel offset(ET), 6" Fuchs have ET36, this is positive in nature and so 72mm(~2.8") is added from the track to get the hub separation.
Bill Verburg
Old 08-12-2018, 02:59 PM
it differs from hub to hub by 2x the wheel offset(ET), 6" Fuchs have ET36, this is positive in nature and so 72mm(~2.8") is subtracted from the track to get the hub separation.
Bill what should the measurement be from face of hub to face if hub?
Old 08-12-2018, 03:04 PM
As noted above track is tire centerline to tire centerline, this coincides w/ wheel centerline to wheel center line. For 6" Fuchs w/ ET36, 72mm(~2.83") needs to be added to track width to get hub width.
so for the pictured car if 54.06" is the track 54.06 + 2.83 = 56.89" is the hub width
I have amended this and my previous post, a negative o/s wheel will move the track width in while a positive o/s wheel(all Fuchs) move the track width out I n each case by 2xs the ET
Bill Verburg
Thanks for all the great info.
What I do know is from my hub face to the inside lip of my none rolled fenders on both sides is 2.75”. And I subtracted 1/4” for clearance.
Old 08-12-2018, 03:27 PM
I really need a nap and my apologies but I need to change back to my original statement, I promise that this is correct
positive o/s wheels move the track in by 2x the wheel ET.
track - 2xET = hub width
for 6" Fuchs w/ ET36
in the above diagram
54.06" - 2x36mm
54.06" - 72mm
54.06" - 2.83"
51.23" is the hub width
Bill Verburg
Old 08-12-2018, 03:42 PM
LJ851's Avatar
54.06" - 2x36mm
54.06" - 72mm
54.06" - 2.83"
Bill, i think your other measurements were correct. The WMS sits closer to the outside of the wheel on a positive offset wheel leaving the wheel centerline (track) inboard of the WMS. The hub to hub width is wider than the track width.
Old 08-12-2018, 05:10 PM
yes you are right, I was totally out of it yesterday afternoon.
positive ET wheels move the center line in from the hub so the wheel ET x2 need to be added to the track ti get the hub width.
Bill Verburg
Old 08-13-2018, 02:25 AM
BURN-BROS's Avatar
I hope it was a good bottle of wine.
Burnham Performance
Old 08-13-2018, 07:20 AM
54.06" - 2x36mm
54.06" - 72mm
54.06" - 2.83"
Thanks again Bill
I'm confidant in the setup I wanted and what we measured too. If I was building a traditional car and setup I would be worried. However considering my car is VERY FAR from traditional I believe the way I had them built will more then satisfy me liking.
Again thanks .
Now I am going to wait patiently at the door for the mail man for my new wheels.
Old 08-13-2018, 09:17 AM
Better than wine, A nice fast 60mi bike ride
Bill Verburg
Old 08-13-2018, 09:27 AM
Arrived and test fired. Absolutely nailed it and what I wanted. No way I could be anymore happy.
Old 08-17-2018, 10:08 AM
I think those look FANTASTIC! Looking forward to seeing them with tires and mounted.
Careful what you wish for...
Old 08-17-2018, 10:56 AM
BURN-BROS's Avatar
Great job Jeremy
Burnham Performance
Old 08-17-2018, 11:03 AM
Please, check the back space on the front 7's
Bill Verburg
Old 08-17-2018, 12:30 PM
