JClanin
jclanin's Avatar
Send a message via Skype™ to jclanin
Outer CV Boot Replacement - HELP! :)
Hi all,
I had a large split in my rear-right-outer CV Boot. I was able to get the axle off and I cut the remaining boot off so I could assess the situation. I notice that the brass/goldish colored coupling that the boot fit over does not seem perfectly round. It actually appears that the axle rod has bent it out of shape/round. (see photo) I'm pretty sure this is not normal correct?
And if this is not normal what do I order to replace? I'm assuming I can just order an entire outer CV and not have to replace the entire axle?
I already ordered/received an outer CV boot kit, but it's just the rubber boot, grease and clamps.
Old 08-12-2018, 04:37 PM
Formerly known as Syzygy
Canada Kev's Avatar
What year is your car? I think on the Carreras and possibly SCs, the outer CV is not user replaceable.
You might still try just replacing the boot if you were so inclined. Don't know if it'll work, but is your other option is replacing the entire axle, what have you got to lose except for the boot cost?
Kevin
Old 08-12-2018, 06:14 PM
Tap it back round with a small hammer.
206 637 4071
Old 08-12-2018, 06:47 PM
JClanin
jclanin's Avatar
It's an '87 911 coupe. I guess I just have to remove/rebuild the inner CV boot as well in order to get the new outer boot back on the axle rod. More work, but a lot less expensive than purchasing a completely new axle assembly.
Old 08-12-2018, 07:03 PM
Hi, I just redid the CV joints on mine and the brass piece was also out of round. If you inspect it, you will see that it is just there as a support for the rubber boot. It does not have to be perfect, just round enough so that the boot makes a good, tight joint. I used a peen hammer, along with whatever was on hand as a small dolly, to tap it back to near round. Nothing to worry about.
good luck,
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 08-12-2018, 11:59 PM
Red Line Service
Marc Bixen's Avatar
jclanan & ALL, The bent axle boot flange is caused by someone rolling the car around with the axle disconnected. We made a special tool to hang the axles when the trans is removed. Beginning 1987 (G50) the outer axle c.v. joint was installed using a "friction welding" technique. Basically non- removable. (to CanadaKev, ALL 1986 and earlier models had removable c.v.'s). Chances are that the boot split because of the bent flange, so it is very important to get it as close to round as possible. Also the color is a Gold Cad or Yellow Cad plating. It is steel underneath, not brass.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 08-13-2018, 02:10 PM
Marc,
Not meaning to disparage a pro Porsche guy, but the "friction welded"
CV joints started with the 1985 1/2 911 with 915 transaxle. Also the axle is larger and uses 110mm
tranny output flanges and inner CV.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-13-2018, 02:38 PM
Canada Kev's Avatar
Thanks for the informatin re: fixed CV joint axles years. Either of those time frames is closer than the foggy data I had rattling around my brain. But I was certain they started that in the later G body cars and your info confirms and makes it more accurate.
Kevin
Old 08-13-2018, 04:10 PM
The large friction welded axles with the 110mm CVs have become very
desirable to folks doing a 3.6 upgrade. Ergo, the 110mm 915 tranny output flanges have become "rare as hen's teeth" because they were only used from '85 1/2 thru '86 and now go for stupid money. I lucked out
and got the axles and flanges for my 3.6 upgrade years ago ('92) when they were cheap.
Old 08-13-2018, 04:39 PM
