Sway bar mount questions
Was peeking underneath my 3.2 the other day and realized that one of my sway bar mounts is trashed.
I'm not confident enough in my welding skills to fix it myself, but I do plan to grind the old one off, clean up the area, and source the new part before I take it to a welder.
A couple questions:
Is the improved stock part good enough for street use? Both my stock mounts have broken now and I'd like to avoid having to make this repair again. I don't track the car.
Can the broken mount contribute to shimmying while braking? I've got a pretty strong vibration happening when I brake at highway speeds. The front rotors are pretty new and I don't feel anything in the wheel, so I was assuming rear rotors, but didn't know if I should hold off and see if fixing the sway mount might solve the problem.
Old 08-17-2018, 07:03 PM
steely's Avatar
I'm interested as well.
I just found out today.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-17-2018, 07:27 PM
Send a message via AIM to fintstone
I would at least upgrade to the WEVO version or similar.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 08-17-2018, 10:23 PM
If you are going to be having new ones welded on.. best to go with the WEVO brand sway bar mount.
I've read MANY posts about these factory mounts breaking apart just from street use.
1987 Porsche 911 Carrera Coupe
Old 08-20-2018, 08:09 AM
Cory M's Avatar
+1
If you've got to weld new ones in just do the Wevo or Jerry Woods mounts (search forum for pics) and be done with it.
Old 08-20-2018, 09:30 AM
cycling has-been
bkreigsr's Avatar
To answer your question, the factory mounts are adequate for street driving, provided you are running stock diameter bars.
In the meantime. disconnect one of the drop links and see if the vibration goes away.
Bill K
Old 08-20-2018, 12:29 PM
175K911's Avatar
I have run the stock part on several Carreras over the past 30 years, but I weld on a triangulation piece. Think of the stock part as a paper clip that you bend back and forth until it finally breaks. Weld a short piece of metal triangulating back to the chassis and it’ll never break again.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 08-20-2018, 05:29 PM
Ed, can you provide a little detail on the triangular piece you referred to?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-20-2018, 05:49 PM
Location: behind the redwood curtain, (humboldt county) california
Wevo
When I inherited my dad's 74 coupe, the right rear bar mount was gone, from the looks of the remnant, it had fatigued. I am guessing that the left mount was also fatigued, but not yet yet broken, so Schneiders shop in Santa Barbara just cut off the failing mount.
Dad ordered the car with carrera bars, 20 & 18 mm, but he was a "low force driver".
I am an "enthusiastic" driver, so I really wanted to get this fixed and do it right. I went with the Wevo and had my mechanic buddy, who is also an excellent welder, grind offf all of the old mounts, shoot all of the bare metal with weld through primer and weld on the Wevo bar mounts. We installed a used 18 mm bar and new drop links and this really tightened up the handling of the car, also primed, painted and under coated the repairs.
The mid year cars have a lot of rear bar mount failures, more so with bigger bars. The Wevo parts are beefy and will get the job done.
Do it right and do it once- wevo gets it done.
Bona Fortuna,
Chris
Last edited by chrismorse; 08-20-2018 at 06:45 PM.. Reason: Disclaimer - not a stock holder, just appreciate a good part.
Old 08-20-2018, 06:38 PM
Diss Member
Quicksilver's Avatar
Bill K
The factory came up with an upgraded version because the original mounts were tearing out of the cars. The upgraded factory version is not really adequate if the car is driven hard for a lot of miles. (Yeah, at 245K miles the upgraded factory mount that Andial installed ripped out again.)
The WEVO RARB Console is a serious upgrade from the factory mount but I like the Jerry Woods mount much better. It can be mounted a bit higher in the car and the extra ground clearance makes a difference with adjustable swaybars.
Found these pictures of the JWE mounts on an old classified forum post...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-20-2018, 09:17 PM
Yeah, I like the Jerry Woods design. Seems better to just move the mount away from the thin sheet metal.
I wonder if this one might be a little easier to weld up, too? I have a MIG and a bit of welding experience.
Old 08-21-2018, 04:12 PM
Cory M's Avatar
I was concerned about the differences in material thickness between the cast Wevo mount and the body sheetmetal, but the Wevo mount welded on super easy. As long as you clean the area well it's no issue.
For the guy asking about the "triangular piece" search Pelican for "sway bar mount reinforcement" or gusset. There are templates you can download and some suppliers may still sell the little sheetmetal piece. It's a pretty simple part to make. I've still had a mount fail with this reinforcement, it basically ripped off the body, but this was on a track car with stiff bars. The reinforced mounts are much stiffer and stronger than stock and work fine for most.
Old 08-22-2018, 08:13 AM
steely's Avatar
I just got the bolt-on mounts (Kit 65-215676-1) from Weltmeister today - they'll get me back on the road and buy me some time.
Dan
Venetian Blue
Old 08-23-2018, 08:20 AM
Cory M, did you find it difficult to weld onto the galvanized frame?
I have a decent MIG welder at home and am pretty tempted to just do this myself since it doesn't look like rocket science.
Old 08-23-2018, 11:46 PM
Cory M's Avatar
It was surprisingly easy. I've welded cages into galvenized cars and it can be challenging, but on the mounts i didn't have any issues. I was afraid of getting enough heat into the thick cast part and not burning through the thin sheetmetal, but that wasn't an issue either. Clean the area well with a grinder and go for it.
Old 08-24-2018, 07:58 AM
porsher
aston@ultrasw.c's Avatar
when cleaning a weld area go slowly, the metal is already pretty thin and you don't want to remove more than necessary
i generally use a sanding disk rather than a grinder
that JWE mount is the best i have seen, i basically fabbed my own parts to do the same thing
you could add a gusset to the t tube to take the lateral load, then you don't need to weld on the sheet metal at all
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 08-24-2018, 11:33 AM
