No high frequent sound from the CDI unit...
Yesterday I had the blowerfan and case on my -74 powdercoated, but today when finished assemblied and ready for start up, there is no high frequent sound from the CDI unit and no or very little voltage to the fuel pump.
I do not see how my painwork is related to the powerloss, but I then again can it be some ground issues. I have ground on the fancase through the coil screws attachment.
Old 08-21-2018, 08:22 AM
Jonny H's Avatar
'74 CDI grounds through the shield wire on the CDI case. The +12V is the centre pin of the 3 pin plug. Check for 12V across these two points with a test bulb.
www.classicretrofit.com
Old 08-21-2018, 08:37 AM
Do get +12V in the centre pin.
By the way, I do hear the frequent sound from the CDI unit, but only if I stick my hear very close. Normaly the sound is very high.
And why do I suddenly get no voltage to the fuel pump...?
Old 08-21-2018, 09:01 AM
Still here
pmax's Avatar
By case, you meant the fan housing ? Check the ground connections around the coil plate.
Old 08-25-2018, 04:14 PM
You’re ground, shielded wire outside
If the wire inside is breaking down the volts to the points is crossing to the shielded wire.
Use 3 alagator clip wires and replace the wires in the harness
Bruce
Old 08-25-2018, 04:21 PM
Under the radar
Trackrash's Avatar
Bruce,
Have you considered writing a book? Might be worth while.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-25-2018, 04:48 PM
Thanks, Gordon
Bruce
Old 08-25-2018, 05:10 PM
