converting to headers... need oil hose solution
2.7L 7R case engine. going with headers. a rubber hose leaving the left side of the engine and crossing to the other side would work if I was running conventional heat exchangers. with headers I'm not sure I can keep such a hose isolated from the header pipes.
your thoughts are appreciated.
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 08-29-2018, 05:01 PM
I would rather be driving
jpnovak's Avatar
Use the early oil crossover line. There is the 26mm version that goes over the bell housing and the 30mm which I think goes underneath the bell housing. Both of these are full metal hard line all the way from the case to the mounting under the engine oil cooler.
Old 08-29-2018, 06:04 PM
like so ?
**News Flash**
Old 08-29-2018, 08:05 PM
Flojo's Avatar
would this from Elephant Racing help?
check their purposed kits:
https://www.elephantracing.com/porsche/911/oil-cooling-for-911/oil-cooler-kits/
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 08-30-2018, 04:36 AM
Chuck does amazing work. I have the pictured line on the shelf & ready to adapt to my system. if it proves inadequate I'll pay Santa Clara a visit. thanks!
**News Flash**
Old 08-30-2018, 08:11 AM
Originally Posted by ty901 View Post
like so ?
Yes. However, the permanently attached flex hose section was prone to leak and was superseded by an all metal version and a separate hose. IMHO, the hard tube section sits close to the exh tubes and should be insulated to minimize heat transfer to engine lube.
Sherwood
Old 08-30-2018, 09:44 AM
thanks Sherwood... this example is how I'm leaning @ the moment as I can make up the hose end to suit my non-stock application.
where might one source insulation ?
**News Flash**
Old 08-30-2018, 10:03 AM
As suggested, purchase just the hard line, then have a hose service (BoxsterGT here) or a local Hoseman service to fabricate the flex hose to your specs. Chuck at ER can also set you up with his “up-and-over” version.
Insulation doesn’t have to be fancy nor extensively applied. There are several off-the-shelf fiberglass and equivalent wraps and sleeves as well as more mundane foil wrapped attic materials that would work.
Old 08-30-2018, 10:24 AM
