converting to headers... need oil hose solution
2.7L 7R case engine. going with headers. a rubber hose leaving the left side of the engine and crossing to the other side would work if I was running conventional heat exchangers. with headers I'm not sure I can keep such a hose isolated from the header pipes.
your thoughts are appreciated.
Unclear on the concept ? Let's see if I can help. 1) You are NOT in the "fast lane" and... 2) You are NOT going "fast enough". **News Flash** You're in the Passing Lane. Any questions ? |
I would rather be driving
Use the early oil crossover line. There is the 26mm version that goes over the bell housing and the 30mm which I think goes underneath the bell housing. Both of these are full metal hard line all the way from the case to the mounting under the engine oil cooler.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
like so ?
would this from Elephant Racing help?
![]() check their purposed kits: https://www.elephantracing.com/porsche/911/oil-cooling-for-911/oil-cooler-kits/
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Chuck does amazing work. I have the pictured line on the shelf & ready to adapt to my system. if it proves inadequate I'll pay Santa Clara a visit. thanks!
Yes. However, the permanently attached flex hose section was prone to leak and was superseded by an all metal version and a separate hose. IMHO, the hard tube section sits close to the exh tubes and should be insulated to minimize heat transfer to engine lube.
Sherwood |
thanks Sherwood... this example is how I'm leaning @ the moment as I can make up the hose end to suit my non-stock application.
where might one source insulation ? ![]()
As suggested, purchase just the hard line, then have a hose service (BoxsterGT here) or a local Hoseman service to fabricate the flex hose to your specs. Chuck at ER can also set you up with his “up-and-over” version.
Insulation doesn’t have to be fancy nor extensively applied. There are several off-the-shelf fiberglass and equivalent wraps and sleeves as well as more mundane foil wrapped attic materials that would work. |
