headlights high and low beam mixed
Hello
My Porsche 911SC from 1980 has a wiring issue with the lights. When I put on the lights the high beam goes on. When I push the indicator the blue light on the dash goes on and the regular headlight go on.
Where should I rewire? At the steering wheel, at the fuse box or at the lights themselves??
Thx!
Old 08-30-2018, 11:14 AM
ROW '78 911 Targa
timmy2's Avatar
Was it working normally and this is a new problem?
Look at this thread on turn signal quick fix if it is new.
turn signal switch quick fix pictures
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-30-2018, 11:41 AM
The problem is there since i own the car. My feeling is the wiring is wrong. The stalk functions ok
Old 08-30-2018, 01:42 PM
ROW '78 911 Targa
timmy2's Avatar
Ok, yellow and white wires at the fuse panel may be mixed up top to bottom.
Take a photo of the first 8 fuses and terminals closest to the front of the car and post it.
Is there a headlight relay mod installed?
Dennis
Old 08-30-2018, 03:01 PM
bad turn signal switch/headlight switch
as Timmy says, install a relay too
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-30-2018, 03:32 PM
ROW '78 911 Targa
timmy2's Avatar
Could be as simple as yellow and white on the wrong terminals at the headlight switch as well.
I am guessing you haven’t had the car a long time.
Edit: looked at your prior posts, 2-3 months of proud ownership.
Post some photos of your car if you are home now.
Dennis
Old 08-30-2018, 03:47 PM
I switched two wires at the headlight itself and it is fixed. Thx!
Old 09-13-2018, 01:18 PM
