Banned
need help: 3 litre SC engine - should I go for carbs, efi or whatever?
What would be the best option, not the most expensive one?
rebuild engine, SSI, lighter flywheel .. is there a comparison somewhere? thanks! |
I'm interested in this question as well. Have a 3.0L SC and thinking either rebuild to something with more displacement and power ~300+ hp or just swap the engine to a 964 3.6L and start from there or be happy with the ~250hp which will probably feel more than adequate in my 75 911S.
1975 911s Restomod, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 1983 BMW R100RT, 1978 R100S, 1989 R100RS, 1991 R100 classic (x2), 2023 Ford F150 Lightning SOLD: 93 R100R, 03 R1150GSA, 85 R100S Mono, 03 996 turbo, 16 Norton 961 Commando, 03 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord, 89 KE100 |
regarding the fact, that to nicely tune up a 3.0 you have to split it (for e.g. S-cams, JE-pistons, 993-pump, etc.), either if it's a Max&Moritz upgrade oder bore-up to a 3.2... this cost money.
And as far as I know it cost way more money than to swap for a larger/later engine. The average price for solid a 3.2 upgrade is between €17.000-20.000 I'd not spend that money vs a good 3.6 correct me if I'm wrong
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Home of the Whopper
964 cams, SSI exhaust, remove some weight.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Speed costs money.........
how fast do you want to go? A typical rebuild with some hot rod upgrades will cost about $10 -$12,000 in parts plus labor. A rebuild done at a good shop will be about $20 - $25K out the door. There are some less expensive things that can be done. Change over to the SSI exhausts for about $2K. Replace the clutch cover with the aluminum one for lower weight and faster revs, about $1K. Change camshafts to 964 cams for a couple of thousand dollars. Have an expert go thru the CIS and make certain it is working "just right", a few hundred dollars. Basic tune up, distributor cap, rotor, plug wires and plugs, again, a couple hundred dollars. If your engine doesn't have any broken cylinder head studs or weak cylinder compression and has good oil pressure, I would leave it alone. Drive it long enough and some or all of the above mentioned problems will show up. That will be the time for a major rebuild. In the end, it is your car and money, make it just the way you want it to be! Happy motoring.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
I did SSI and weight reduction.
engine is sound and trans rebuilt. I read about a + of 40hp (SSI, 964 cams 20/21 and 9,3/9,8 pistons)... true?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 08-31-2018 at 05:44 AM.. |
Eva
If you've got the $, the above + ITB's. More power, better drive-ability, better fuel economy, killer look and the carb'd sound... no brainer
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
My mechanic has given me this estimate of what it would look like to do a 3.0L rebuild with upgrades to get over 300hp. Anyone able to comment on whether this seems reasonable? This does not include a separate estimate of ~$6k for headers and muffler. In addition to this I am assuming I will need a front corner oil cooler to fit under the early 930 front valence which I would estimate as a $3k job. So by this standard I'm looking at an estimate of ~$27k....and I always assume there will be something new to add as the work begins. Still have not pulled the trigger on this as I may be able to get a freshly rebuilt 964 3.6 engine instead for around $19k
Runnin on empty
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
Runnin on empty
Light flywheel is for racing. Not recommended for everyday driving.
Spiderman
Wouldn't this also require another cost item to get all this work work properly, not just the adding parts and rebuilding ? What compression would you be going for to hit 300 hp, that seems like a very difficult number to hit.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
I have lightened flywheel and clutch in both of my cars. They work just fine, you don't even notice the difference taking off from a stop. You do notice the engine revs quicker. And I think you could do the Triumph ITB for a little more than the Carbs with better performance when done.
Derrick |
Fleabit peanut monkey
The 74 RSR was 226 and the 84 SCRS was 247 probably using racing gas. In the countless hours burned on this forum, I have not seen normally aspirated 3.0 dyno graphs that demonstrate 300hp. Guessing it's been done but you would really have to have a screaming spinner that would require special rods and retainers on top of the other goodies. Also, a high performance oil pump and other oiling tricks. If I am full of wind and you can get 300hp, I don't think you would like it.
1981 911SC Targa |
![]() Here is my SC engine entirely rebuilt into a 3.2 short stroke, new everything, upgraded rods, valve train etc. 10.5:1, twin plug, and high butterfly intake with coil on plug EFI. No dyno yet, as it is just being completed. Cost? Don't expect $25k to cover it.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
What concerns me about the estimate I've been given is the use of the words 'custom' and 'special' numerous times without a good explanation of what that means. The only thing that is detailed extremely clearly is the amount of $$ I'll be shelling out. I will be requesting a lot more detail before signing on to the build.
Runnin on empty
[QUOTE=1979-930;10163334]Not true. It's just something that people repeat because they heard it one time.
I have lightened flywheel and clutch in both of my cars. They work just fine, you don't even notice the difference taking off from a stop. You do notice the engine revs quicker. https://mechanics.stackexchange.com/questions/28561/what-are-the-benefits-of-a-lightweight-flywheel-and-why-arent-they-lightweight Please don’t assume that I’m just repeating something. Hey, whatever works for you.
Eva
Seems awfully inexpensive ![]() Be careful, because once you see half an estimate like this one, you'll give the go ahead to tear the motor apart...then you're committed, and when the finished product has a $35k price tag you're not going to be too happy. Anyone here can tell you, $17.5 is about the halfway point to a 300hp 3.0L
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- Last edited by 911SauCy; 08-31-2018 at 07:34 AM.. |
That is a nice looking engine! Where did you have it built?
That write up is a joke. But it's on the internet, so it must be fact.
Derrick |
Rasant Products in SoCal built the engine. Andrew is very highly respected builder and designer of engine management systems. The intake system was put together by Marc Zurlinden at Revival Road in Monterey. He and Andrew worked closely together to create the completed engine.
