Can someone confirm for me - with engine not running, if I have a fuel pump relay bypass going, and the ignition "on" then there should be power to the TTY, WUR, and AAR - correct? ** Pmax gave me the answer Jason
'79 911SC Targa Last edited by LIRS6; 09-09-2018 at 07:18 PM.. |
Jason
'79 911SC Targa |
Too many cooks in the kitchen.........
Jason, I have been following this thread with interest right from the beginning and curious to see how it turns out. Stick with SkiVT (Mike S.) and we spent a lot of time together diagnosing his CIS problem. He did a lot of good investigative work similar to yours. He has given you sage advises and keep working with him till you fix the problem. Mike S. has a very systematic approach in troubleshooting and feedback from him was very good. Do the same for him. Keep us posted. Tony |
Hope all is well with you Tony. Jason
'79 911SC Targa |
testing methodology question as I can't reconcile the last two videos you posted: you can only test CCP once every 6 - 8 hrs, regardless of if you tested with or without starting your engine. No Engine Start Method: you come out after the car sits for 8 hrs and the engine and WUR are both cold. You use your jumper and test pressures without starting the engine, seeing CCP first. Once you plug the WUR in and get to your max WCP, you have a warm WUR. If you then start the engine, you are at WCP and not CCP. Engine Start Method: you come out after the car sits for 8 hrs and with your pressure gauge hooked up, you start the engine. You can observe CCP in the first 10 seconds or so. The WUR begins warming, mostly by the bimetallic strip and a little with engine heat, and you end up at WCP. In this method, you now have a warm engine and warm WUR. Using either method, you need to let the WUR cool off to again see CCP.
The problem with testing pressure with an engine start is things like the TTV also come into play. No engine start method lets you use things like a vacuum pump to test CCP and WCP, with and without vacuum applied. However, it also means you need to test the TTV separately as the WUR can have correct CCP and WCP both with and without vacuum applied AND things still not work correctly. If your TTV either doesn't work to hold off vacuum OR the vacuum hoses are not hooked up correctly, you will still have a cold idle problem. Ambient Temp: your CCP is different across different daily temperatures (see the WUR chart). So if it is 100 out, your CCP will be higher than if it is 65 out. WCP cares less as the bimetallic heater and engine warmth overcomes cold ambient air. Your video and your pressure results: you have posted CCP without engine started twice with very close results at similar ambient. You then have the video showing an immediate CCP at 3.0. If the vacuum lines are correctly hooked up and the TTV is working and ambient was similar, this isn't possible. Did you let the WUR completely cool down before starting the engine? Another way to test the CCP is start the engine after sitting for 8 hrs, with a golf tee plugging the WUR to TTV vacuum line. This guarantees no vacuum to the WUR and again, you will see CCP for the first 10 to 15 seconds. The CCP should be the same 2.1 you saw without starting the engine. Last part of my rambling: testing more than one thing at a time makes it hard to figure out what exactly fixes the problem. The AAR is important but I wouldn't go there until you have this WUR and TTV thing completely figured out. BTW the easiest way to see if the AAR is contributing to your problem is to connect the two hoses at the AAR together using a piece of pipe (so bypass the AAR). You are guaranteed to have air as the AAR can't obstruct airflow.
1983SC RoW Last edited by SkiVT; 09-10-2018 at 04:49 AM.. |
TTV test and evaluation........well explained.
Mike, Only a person who has a good understanding of how the system works could deliver such a message. I am very impressed with your work. There is another individual in this forum that reminds me of you with good skill in delivering a clear and concise message...........is Ossiblue (Larry). Hope LJ is doing well. Jayson, Communicate with Mike. He has done this troubleshooting before and with a good understanding of what is going on in the system. And keep us posted. Tony |
Jason
'79 911SC Targa |
Still here
I will add that based on my digging into OLD threads the posts of psalt, Jim Williams, Peter Zimmerman and John Walker were exceptionally informative whenever the CIS topics came up. Pay attention to every word they write ! LIRS6, You're in good hands now but your AAR test, assuming it's done correctly which appears to be the case, does show it's not closing as it should be. Good luck ! Keep us posted. Last edited by pmax; 09-10-2018 at 10:07 AM.. |
Jason
'79 911SC Targa |
Still here
Also, the AAR should be closed by the end of your WUR warm up fuel pressure test (w/o engine running). Last edited by pmax; 09-10-2018 at 07:12 PM.. |
Post #31..........
Jason,
Please review post #31. If the information you posted (red letters) regarding WCP are correct, then the WUR is one of your problems and it will never go away. You could spend all the time you want tinkering your CIS. Maybe you could get lucky. But you could not rely on LUCK all time to fix your nagging CIS problem. What you need is a set good working CIS components (WUR, FD, AAR, TTV, etc.) that are tested and confirmed good. Right now you are hoping that all these components are all good and working fine. But you do not know that as fact. Tony |
Thanks, Jason
'79 911SC Targa |
Yes there are two allen head screws to remove and it comes off the engine. They are a little tough to get to. Also need to disconnect both hoses and the power connection.
Test and confirm........
Jason, There are several CIS components you need to test and evaluate to get your engine to run flawlessly. Check the following: FD WUR AAR AAV DV TTV CSV Fuel injectors Including air box/POV and intake runner boots. Etc. All the above CIS components could be bench tested conveniently by DIYers like you or me using home-made tools. Or send them to me for FREE testing. Just take care of the shipping cost. Or send them to someone who will do it for FREE and I won’t be offended. Tony |
Because I am curious, Tony: are the wcp pressure readings in black text in spec w/o vacuum? And the red text out of spec w/o vacuum? The higher readings at lower ambient are confusing but I thought the black text was in spec. Either way test and confirm as you already said.
Thanks, Jason
'79 911SC Targa Last edited by LIRS6; 09-10-2018 at 06:51 PM.. |
WUR-045 WCP spec.........
Mike, Take a look at the WCP chart for WUR-045: WCP (no vac applied): 2.7 ~ 3.1 bar (See PSM) WCP (with vac applied): 3.2 ~ 3.6 bar (See PSM) Jason got 3.5 bar (no vac) and 3.8 bar (with vac). See the red letter in post #31. These values are out for the specified range for WCP’s. Secondly, you want a 0.5~0.6 bar difference between WCP’s (with and w/o vac). His WUR was giving only 0.30 bar delta. Jason’s WCP values are too high for WUR-045. Your WUR-089 has a different chart profile than -045. Tony |
Thanks Tony. I was focused on the results in the post below and not on the posted response to your question (at bottom). I was comparing the results immediately below to the various 045 WUR spec pages (several different versions from other threads). The difference in these sets of numbers is mysterious but no question 3.5 and 3.8 are high.
*********************************************** Originally Posted by LIRS6 View Post The car : '79 SC (USA) Original 3.0 with WUR ending 045 Red font are readings taken today. TTV hoses reversed to normal position (hose from Decel Valve in middle, WUR hose on side) Temp : 74 deg F 66 deg F Test results : FP only - engine not running System pressure: 4.9 bar. 4.8 Bar Cold pressure : 2.1 bar. 2.3 Bar WUR Power connected 30 secs : 2.2 bar / 31.9 psi. 2.55 Bar 60 secs : 2.45 bar / 35.5 psi. . 2.6 Bar 90 secs : 2.7 bar / 39.2 psi. 2.9 Bar 120 secs : 2.8 bar / 40.6 psi. 3.0 Bar 150 secs : 2.95 bar / 42.9 psi. 3.2 Bar 180 secs : 3.03 bar / 43.9 psi. 3.3 Bar 210 secs : 3.1 bar / 44.97 psi. 3.35 240 secs : 3.1 bar / 44.97 psi. 3.4 Bar 270 secs : 3.13 bar / 45.5 psi. 3.4 Bar ************************************************** ************** Originally Posted by boyt911sc View Post Jason, What are your control fuel pressures at: a). Initial CCP with and without vacuum?3.0 Bar @ 73F with vacuum - haven't done it w/o vacuum b). WCP with and without vacuum after 5 mins.? 3.8 Bar / 3.5 Bar (Am I correct in believing that if I disconnect the vac hose to the WUR, that I am testing FP "without vacuum"?)
1983SC RoW |
I am reminded of a previous question that I had - Am I correct in believing that if I disconnect the vac hose to the WUR, that I am testing FP "without vacuum"? If not, what is the correct procedure to test?
Thanks, Jason
'79 911SC Targa |
Testing without engine running: pressures are without vacuum UNLESS you hook up your Mightyvac to the WUR and ad vacuum. I use either the hose disconnect from the TTV and plugged to the Mightyvac or a separate hose from the Mightyvac to the WUR with the WUR to TTV hose disconnected. I would use the no-engine running test if it were me.
Testing with engine running: best way is to plug the line from WUR to TTV. It may also be w/o vacuum just by disconnecting that hose like you did in your video, but I am not 100% sure on that. Honestly, I would Fedex the WUR to Tony for his free diagnostic. Obviously your call on the next step.
1983SC RoW |
