steve 911T SWB..
one more time but very specific! 3,2 US vs EU engine
hi friends,
sorry to bother with this question but didn't find the answer i was looking for in the research ....
i have a US 3,2 carrera with the 207 ps engine and of cours low compression pistons
this winter i will refresh the car an i wanted to do the same with the engine ( 187.000 miles).... as i can get very cheap P&C EU specific new, i was thinking about this change
so my question is :
if i want to change my engine to EU specificity (231ps) ..... can i change just the P&C or do i need to change other parts ??
will also change the chip with a SW chip of course
thanks
steve
Old 09-15-2018, 01:36 PM
Steve,
Depending on the year and actual variant the differences between the 3.2 engines is limited to compression ratio, ecu, exhaust (cat or non cat) and air injection.
By changing to higher compression p&c's and installing a Steve Wong chip I expect you would at least achieve the higher power rating.
Probably the next cost effective modification would be to change the mufflers to a bypass pipe and either a M&K or Monty or Dansk Motorsport at the rear.
Old 09-15-2018, 05:26 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
You may be able to get the "bigger" SSI (see thread elsewhere at Pelican), at a good price as that is also coming out of Europe. I suspect that would add some power as well.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 09-15-2018, 11:43 PM
steve 911T SWB..
Originally Posted by Peter M View Post
Steve,
thanks, my 3,2 is from 1984 with the standard US engine
being located in Europe i have already taken away the cat, put headers and a B&B exhaust 2in 2out plus a SW chip... have 98ron gas here
but while doing the engine i thought that changing to the european pistons that would be a nice idea if i have not to modifie other parts .
thanks for the answers
steve
Old 09-16-2018, 12:53 AM
