Wipers won't Stop: Relay, Stalk, or Both??
'78 SC. When I parked the car yesterday I heard a faint clicking sound (kind of like a clock) after I shut off the ignition. Sounded like it was coming from behind the speedo, but was in a hurry so did not investigate further. Started up just fine this morning, but now the windshield wipers are going on intermittent, even with the stalk in an off position.
So I'm now thinking the obvious...the clicking was the wiper relay. I can replace the relay easy enough, but do you think the issue may be caused by the stalk switches not operating correctly?
Before I open things up, I would love to hear your collective opinions. Thanks!!
1978 911 SC Targa
2007 Boxster (sold)
Old 09-23-2018, 10:49 AM
I am not an expert, that said basic troubleshooting tells if the relay is making clicking sounds continously it is getting continious power. Thus doing its job i would suspect the power coming into the relay(from stalk). If you can pull the relay you can check it by making a continuity check across the switch. If the relay is disconected from power and the normaly open switch reads 0 ohms the relay is bad. At the same time you should be able to check power coming into the relay. Check the voltage an and change the position of the stalk switch. Power should come and go with switch position. Unfortunatly it may not be as easy as i described you may need a schematic of the circuit.
Hope this helps
Old 09-23-2018, 11:16 AM
If the "Park" contacts in the motor/gearbox are corroded/out of adjustment then the wipers will continue to run with wiper switch turned off. Just another possibility.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 09-23-2018, 12:07 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Wipers.
Have you checked that the round variable wiper speed knob on the dash is CCW?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-23-2018, 12:55 PM
T77911S's Avatar
bingo.
on my 930 the wiper plug is right under the dash near the steering column, unplug it when the wipers get to their parked position. I keep putting off pulling my wiper motor to fix the same thing on my 930.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-24-2018, 02:55 AM
Gerry
That was it! I love it when the problem is due to simple owner ignorance and can be fixed quickly at no cost.
Thank you to all who responded.
1978 911 SC Targa
2007 Boxster (sold)
Old 09-24-2018, 04:41 AM
