What's Facebook?
turborat's Avatar
Broken steering column mount
Hello, thought I might share a recent repair of my ‘80 SC steering column mount. Making the transition into the esses at Road Atlanta, the column mount snapped creating the “swing-away” steering wheel reminiscent of the mid-sixties Lincoln and Thunderbird. A trakside attempt to weld the bracket failed. Probably because it looks to be a cast part.
I pulled the column out and knocked off the factory weld with a cold chisle. Then set out to find a solution. The obvious choice that came to my mind was a tube clamp. I found 1 5/8” roll bar clamp for ballast weight. To get the correct drop distance I added 1/4” x 1” steel bar. The clamp has a 1/2” x 16 thread for the ballast bolt. So I cut a piece of steel all thread the exact length and threaded the steel bar. I then spot welded the bar to the top of the all-thread and then drilled and tapped the mount holes for the tub. Cheers
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 09-25-2018, 06:44 AM
