What happens if I turn on my car without an engine?
I took my engine and trans out...
I need to roll down my windows and was wondering if I can hook up my battery, turn the key to get power to my door windows and roll them down???
(I need to take off my doors and remove the glass)
1987 Porsche 911 Carrera Coupe
Old 10-01-2018, 06:58 AM
nothing. You can use the window motors.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-01-2018, 07:09 AM
so the fuel pump won't suddenly kick on and start spraying fuel everywhere?
Old 10-01-2018, 07:16 AM
No, the fuel pump won't run till the ECU sees flywheel pulses. Ergo,
no engine no pulses from flywheel. If it makes you feel more comfortable,
unplug your DME relay.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 10-01-2018, 07:27 AM
gearhead
You’ll blow up your engine.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-01-2018, 07:55 AM
I would rather be driving
jpnovak's Avatar
tape off the positive lead that normally goes to the starter. Bad things happen when it grounds against the chassis under the passenger seat pan. Otherwise, you are good to go.
yes, A motronic will not trigger the fuel pump. but I would probably pull the relay as a precaution.
Old 10-01-2018, 08:18 AM
Formerly known as Syzygy
Canada Kev's Avatar
What happens??
You stick your head out the window and yell out, "Vroom, vroom, vrooOOOOm..."
But maybe that's just me.
Kevin
Old 10-01-2018, 04:58 PM
Kraftwerk's Avatar
Is this a trick question?
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 10-01-2018, 07:38 PM
good idea on the starter... I'll double check other lead wires, just in case.
Old 10-01-2018, 08:11 PM
