Verifying engine and chassis number on 1967 911
We have a 1967 911 and are very confused as to how to verify if our engine number is correct for the car. We bought it in 1998 as a "barn find" and have lovingly restored it over the years. The numbers we have are:
306617
901/05 6679
968606
Please help us figure out if our numbers appear correct.
Thank you
Old 10-04-2018, 03:27 PM
gearhead
That engine number is wrong. 2nd number should be a 0. Look more closely at it.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-04-2018, 04:43 PM
Matt thank you for responding... we finally figured out our issue.. we were looking at the number in the wrong direction (i.e. actually upside down)... our number is actually the period correct # 909896... thus the confusion since all 6 digits can be read either upside down or right side up...
Old 10-13-2018, 06:32 PM
gearhead
Whoa. Mind blown.
Old 10-13-2018, 07:25 PM
djpateman's Avatar
It is quite possible that the engine matches; it is reasonably close to what I would expect. However only with a COA or Kardex can we be certain. I can assist getting the Kardex which may have more info than the COA. These days the engine & trans #'s need to be provided to PCNA and they will confirm IF they match. If you look at the VIN stamped into the front trunk and there is no S appended to it, if you look at the type box on the aluminum tag on the front slam panel and it only says 911, and if you look at the paint tag and the VIN does not have an S appended to it, then you do not have a 911S and the engine # is more likely to be original. It is interesting that from 306614 to 306619 all others are 911S.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-16-2018, 06:58 PM
What would a Kardex cost? I just received my coa, my 69 911e clearly came with the comfort package, yet it's not listed on the coa. Is that because it was standard on all 69 911e's?
Old 10-18-2018, 06:17 AM
