Reinstalled my windshield about a month ago with the improved URO version. Fit just fine with no problems.
Too bad the market is probably too small for Safelite or the such to create a totally new windshield that just glues in like the rest of the modern cars these days. Boy, that would be the cats meow.
If someone gets in an accident and sues everyone, the manufacturer of the reproduction part can simply point to the original designer. It's a lot messier if a company creates it's own design, which they'll have to defend in court (even if their part had absolutely nothing to do with the accident) and a non-technical but sympathetic jury could easily vote with their emotions instead of logic. |
Newest Uro windshield seal doesn’t fit very well
I’m hunting for my receipt, I’d like a replacement Uro, what I have is not ok.
Happy to share that the latest new Uro seal for the 911 windshield is excellent. Fits perfectly and has a nice generous surface area to seal things up correctly.
Can the URO rep on here comment on type of rubber used to make this seal, and it's expected lifespan outdoors in sun and weather. I am very frustrated with modern rubber parts deteriorating quickly compared to vintage parts.
Lots of things to go cheap on....windshield and window seals are not them... nor are electrical items.
In another thread on this subject a Pelican installed the NEW Uro seal and had many pictures to verify how much better it fit than even the Porsche seal. It had a wider border and covered much better to the edges. Check the many pictures from that thread.http://forums.pelicanparts.com/porsche-911-technical-forum/998122-re-designed-new-uro-windshield-seal-review.html I have a brand new in the bag genuine Porsche front seal waiting for install, but I'll put it to the side and order the URO with it's much more reasonable price. I'll let you know how it turns out. |
The latest URO corners smoke OEM. Even my installer was titillated with the install experience. And he’s been at it since 1971 with his glass shop.
Conventional wisdom I had read was to get the porsche genuine seal. Seems like the recent posts indicate the URO seal for the front window is now a good option.
I currently have all the glass out of my car and will need all new seals. Do the rear window seals from URO work good as well? What about the quarter windows, what is the best seal to use there? |
Interesting..... my issue with Chinese rubber has usually been the early wear out/degrading and the hit/miss from year to year from the same provider.
I've no idea who provides Porsche rubber but the last time I replaced the front window (3years ago) with Porsche rubber it was excellent in fit and still looks new... All my glass will be out in a month or so …. crapshoot. |
P car getting a facelift and a total paint job....so I could use your new found skill set. |
Unfortunately I had a bad experience with the (new) URO seal. Multiple attempts by a local shop with plenty of experience of this job couldn't get the glass and seal to seat correctly. They even tried a different windshield in case it was a tolerance issue on the glass, but no luck. In the end a Porsche seal was ordered and the windshield went in without issue. The fit looks good and no leaks.
The guy doing the install reported that he felt the URO seal wasn't stiff enough for the particular combination of glass and frame in my car. Fortunately for me he stood by his quote of 2 hours labour. I don't want to criticize the URO seal as my guess is that this was just a particularly unlucky combination of components, and for most applications the URO seal would be fine. I still have the URO seal and would be happy to pass it on to anyone else who wants to give it a try (for the price of postage from Canada). |
Buy both.
Try URO first. If good, return OEM If bad, use OEM, return URO. |
Since we are on this topic and I know I need to replace mine due to a leak can we confirm that the updated URO part number is URO-009765? |
Mine was a factory seal. I paid $$$$ to have it installed by a guy with 20 years of ferrari and porsche experience removing and reinstalling windows.. Apparently all the high end body shops use him.
He really is knowledgeable to point of being able to install targa rear glass ect.. My 930 still had a 1/8 inch gap after his best efforts. Drove directly to my porsche mechanic. The seal was installed to beyond factory condition! Apparently the seals fitment is very dependent on the correct alignment of the trim pieces. Porsche’s of this era are HANDMADE so these kinds of things often require a very knowledgeable and experienced professional to achieve the level of excellence porsche intended. https://uploads.tapatalk-cdn.com/201...e55469c74a.jpg |
| All times are GMT -8. The time now is 08:47 PM. |
