Question Premuffler install with diff o2 sensor location???
Installing a new pre-muffler to replace the original catalytic convertor on my 3.2.
I noticed that the location for the O2 sensor on the new pre-muffler is on the other end (the muffler end not the crossover pipe end).
Not sure how to go about the installation, looks like the stock O2 sensor will not reach the new location.
Anyone had a similar issue?
Do I need to buy a new O2 sensor with longer wires etc?
Old 10-11-2018, 07:37 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
That's strange. guess you could splice an extension into the wires or leave it disconnected. I believe it only effects idle mixture. I would get a different pre-muffler.
Chris
89 Carrera
Old 10-12-2018, 06:44 AM
Northern Motorhead
wildcat077's Avatar
Not sure what you're installing , but when i still had a 3.2 in my car, i installed a MK unit which i think is definitely the best one as the O2 bung captures both banks as compared to some other units which only capture one.The wiring was all good ... although as Chris mentions you can always splice the wiring with a good solder joint !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-12-2018, 10:01 AM
cmcfaul's Avatar
I just installed a Fabspeed and the O2 sensor was exactly where the old one went.
Chris
89 Carrera
Old 10-12-2018, 10:35 AM
+1 M&K pre-muffler with O2 sensor, looking aft. What kind of pre-muffler are you using?
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 10-12-2018, 05:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Go to a muffler shop, have them relocate the bung and weld up the old location.
'85 Carrera Targa
PCA/POC
Old 10-12-2018, 05:23 PM
Pic of premuffler
This is a pic of what I am using, not sure what the correct name for it is, I think it is called a ram horn power pipe.
Old 10-12-2018, 09:10 PM
That Guy
Techno Duck's Avatar
The sensor is too far forward to take full advantage of reading at the merge collector. They should have just put it closer to the inlet flanges at this point. That an interesting design, i guess they were going for an equal length runner.
Some aftermarket chips are meant to run with the o2 sensor disconnected, similar to the euro cars. The o2 sensor does correct your AFR at idle and part throttle cruise. The computer reverts to default fuel maps at WOT. If your sensor is old, go buy a universal Bosch 3-wire. It comes with a long harness and a splice kit (posi-lock connectors).
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-12-2018, 09:18 PM
Install
Thanks for the replies. Anyone else installed this kind of premuffler?
Old 10-14-2018, 11:53 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Stated in the instruction sheets for Bosch universal O2 sensors a warning in bold: "Do not solder connections, use supplied crimps only". The universal ones are the cheapest way to go and still get a quality product.
1986 Targa Guards Red
2021 MT09 SP
Old 10-15-2018, 04:19 AM
shh-the robot is sleeping
Could you just splice in an extension? That would seem simplest to me.
'88 911 Coupe, 69k miles
Old 10-15-2018, 04:21 AM
