Reusing Schnorr washers?
Can they be re-used? I kinda think I heard they are one-time use only. Application is for the motor and tranny mounts (the large bolts). Thanks Pelicans! And BTW - does anyone have 4 M12 Schnorr washers hanging about in the DC area?
Old 10-13-2018, 11:02 AM
walt's Avatar
I have these on my driveshafts and have replaced the bolts and washers with new each time. Technically, I am not sure the correct answer but always err on the safe side.
Walt
82SC 3.0
81SC 3.6
Old 10-13-2018, 01:08 PM
The 9 Store
They are for one time use. All the big fastener companies carry them.
All used parts sold as is.
Old 10-13-2018, 01:48 PM
Try Belmetric. They ship fast.
Old 10-13-2018, 01:53 PM
Just curious, what Schnorr washers? The M12 doesn't have a lock washer, just a torque value. I just swapped out my motor mounts and I am wondering about this. The parts list doesn't list any lock washers...
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 10-13-2018, 03:29 PM
Once a friend of Cliff
juanbenae's Avatar
i've used standard stainless lock washers when schnorr were not at hand. never lost an axle even on my racecar...
Old 10-13-2018, 03:38 PM
petercory
Using Stage 8 Fasteners, they'll never loosen up - cheap insurance!!!
Old 10-13-2018, 07:46 PM
Functionista
manbridge 74's Avatar
I’ve reused in a pinch. Properly torqued axle bolts will not back out.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-13-2018, 08:00 PM
Jeff Alton's Avatar
^^^ Exactly. Clean the threads on the bolts and out put flange. Torque properly and never worry about it.
www.turn3autosport.com
Old 10-13-2018, 09:05 PM
So, my application is for the motor and tranny mounts. Same logic still applies?
Old 10-14-2018, 07:08 AM
Harpo's Avatar
Ditto and they are reusable
Old 10-14-2018, 08:57 AM
Walt Fricke's Avatar
There have been lots of discussions about this and related issues. Some favor doing exactly what Porsche did and nothing else. When it comes to these special washers, Porsche did not always use them for various applications, which suggests maybe it doesn't matter, really.
Jeff nailed what is the real key to keeping fasteners tight and in place - enough bolt stretch, which is approximated by torque. That's what race engineer Carroll Smith says in his book on fasteners. He says that even safety wiring won't do the trick if the stretch (and in the case of a bolted joint, the resulting clamping load on rotating reversing mating surfaces)is inadequate.
I use no washers and none of those plates with two holes on my 8mm bolt size CVs, and I have never had one which was properly torqued back out.
So it is a question of your comfort level, I guess - you can't go wrong if you have adequate torque.
Of course, not a big expense for those washers, and if sending off for new Schnorr's doesn't affect your schedule and you like the idea of following the actual factory manual for your model, why not. It makes sense that you try to keep the metal to metal joints on both sides of the CV pretty grease free.
And checking the torque of all of them after 100 or so miles of driving isn't a bad idea - if you missed something you can catch it. When torqueing mine I like to go one extra bolt around just to make sure I got all of them.
Old 10-14-2018, 09:44 PM
T77911S's Avatar
you can get a bag of 50 from Fastenal pretty cheap, compared to what they are sold for EA.
you can also get the bolts in 5mm lengths. you want 2-3 threads sticking out past the flange.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-15-2018, 03:47 AM
Wildman Emeritus
A dab of paint on the bolt and mating surface after torqued will tell you visually if they have backed out at all. Easy to do and easily viewed.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-15-2018, 07:01 AM
I have reused those big schnorr washers for years, basically because I don't want to bother shopping for them. Those are massive bolts, with lots of torque, which are loaded axially. Totally different scenario than the axles, which are undersized bolts, with very little torque, being loaded radially (and rotationally, to boot!)
You could 100% get away with simple lock washers as well. I don't see any real reason for Schorr washers on the engine and tranny mounts.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-15-2018, 09:49 AM
Shaun @ Tru6's Avatar
I always supply new Schnorr, lock and wave washers in every customer's job.
Tru6 Restoration & Design
Old 10-15-2018, 09:58 AM
shh-the robot is sleeping
Do not reuse
'88 911 Coupe, 69k miles
Old 10-15-2018, 10:08 AM
