Manufacturers will engineer around known and available materials..
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Eva
Now I must inquire...
Is there a different thought path if say someone (SauCy) recently installed the larger of the 2 sized headers in question on a stock 3.0...but that engine is a true Euro spec 930/10 with large intake runners and higher CR...? With an M&K 911R muffler...of course
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Brian sorry to disagree but type of material doesn't dictate wall thickness.. More common materials used in stainless are .065, .049, .036.. 304vs 321vs any other type doesn't matter its about what the Mill makes and how big that particular size has for a market..
When too big is used a similar effect occurs but in reverse, It's less noticeable because you aren't usually going for max power at the bottom end of the rev range. What does happen is that the flow slows down, the bigger the pipe the more it slows. The issue is further complicated by the use of a muffler. each muffler affects the system in it's own way, adding more or less back pressure. The one sure thing that any muffler does is inhibit acoustic tuning. Stainless is the preferred material for longevity but also adds a small amount of heat insulation. The hotter the gasses, all else being equal, the faster they move the more efficient the exhaust. Some will add external mat insulation but this raises the issue of additional corrosion which will shorten service life.
911SauCy, are you asking a good question. From the information referenced here it looks like 1.5 is good.
The 930/10 is a common motor used in PCA E class racing. Some of those cars are REALLY expensive builds. I would assume they are using 1.5. I may ask on Renn where some of them post from time to time. Last edited by jamesjedi; 10-15-2018 at 03:13 PM.. |
Eva
Racer
You are so right. I don’t know what that guy is talking about.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I think it is/was a matter of semantics. It is true that the type of material does not dictate the wall thickness of tubing from a manufacturing standpoint, it is the application that dictates the thickness.
Here's a comparison of the exhaust gas flow into each pipe/Sec for various engines.
here Volumetric Efficiency is assumed to be 100% and the acoustic effects aren't considered ![]() note that at say 15 l/s; the 2.7 is @ 4000, the 3.0@3800, the 3.2@3200, the 3.6@3000
