Designer King
Paulporsche's Avatar
Dash Lamp Replacement Question
I want to replace my current Philips 12829 12v 2w dash lamps with Sylvania 3893 12v 4w lamps. I see these are interchangeable. Is there any issue due to the increased wattage? Do I need a relay or a change in wiring or fuses? Per Ohm's Law I wouldn't think so but I'm just checking.
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-16-2018, 11:36 AM
Runnin on empty
acme911's Avatar
Have you considered LED’s?
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 10-16-2018, 12:09 PM
Under the radar
Trackrash's Avatar
I guess you may be OK, due to the fact that you can adjust the brightness.
There was a tech article about adding a fuse to the dash light circuit as there have been fires known to start if there is a short.....
From my experience Porsche used the smallest wire size possible in most of their electrical circuits in the older cars, so let us know how it works out for you.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-16-2018, 12:53 PM
Designer King
I may just go with Engelbert's LEDs after all.
Paul
Old 10-16-2018, 01:43 PM
pete3799's Avatar
You won't be disappointed with the LED's.
Pete
79 911SC RoW
Old 10-16-2018, 02:05 PM
Runnin on empty
acme911's Avatar
I just went full on LED's inside and out. Last page in this thread:
A Werk in Progress
Old 10-16-2018, 03:53 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Here are a few items for your review.
Fusing & relays was not Porsche's finest hour on the 3.2 & prior 911's.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-16-2018, 04:45 PM
MBAtarga's Avatar
Is there an official Porsche part number for the fuse assembly to install on the dash wiring?
Mark
'83 SC Targa - since 5/5/2001
Old 10-16-2018, 05:39 PM
Designer King
Thanks for that, Gerry.
Nice "werk" Acme.
Paul
Old 10-16-2018, 07:07 PM
famoroso's Avatar
I run bright white and classic white LEDs in my two cars. They are both great. The classic version are pretty white, but not as harsh as the bright white.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 10-17-2018, 05:00 AM
Designer King
Just placed an order to Engelbert for the Vintage White. Anybody know how long shipping takes to MA?
Paul
Old 10-17-2018, 08:24 AM
Fuse the interior light circuit, even if you don't fit LEDs. Good quality ATO fuse holder is like $5.
Doubling the load on a circuit responsible for many dash fires over the years? Not a great idea.
Usually need to fiddle with BA9 LED replacements; the socket isn't polarity sensitive, but the LEDs mounted in the base are. Many larger LED replacements work either way, but no-one seems to bother for these smaller bulbs (very likely a packaging issue).
If switching out the fuel warning lamp, run the fuel down until it's lit first, much easier to get the correct polarity... It is very nice to get a deep red warning light instead of the faded pink too...
AFAIK, all bulb-replacement LEDs have a load resistor built in (to reduce the car's 12V to the 1.8-3.3V LEDs operate on), but some LEDs intended for "smarter" cars have more load - either to simulate a real bulb and avoid "bulb out" warnings, or for flasher bulbs intended to operate with standard relays (as opposed to replacement LED friendly relays).
Those resistors can negate some of the benefit of LEDs, as they load the original wiring just as much as bulbs. They won't melt plastic carriers (e.g. in the heating panel) though...
First off, props for the middie love
Secondly - really? I tried that years ago - just for the interior... Hit a number of snags...
Did you find festoon LED replacements for the courtesy lights that aren't polarity-sensitive? I tried to - but failed.
Without that, least on my car, seems that you can't have the courtesy lights work on both a) the door opening and b) when you switch them on manually. Filaments don't care about polarity - but LEDs do, and I have to swap them around 180 degrees to get the "other" circuit to work...
Also, AFAIK, the generator warning light needs the resistance/load provided by the wire filament to perform the essential task of making the alternator produce current (part of the exciter circuit). More importantly, pretty sure that current has to flow both ways through that lamp. So wouldn't respond too well to an LED there, as they only pass current one way...
I also noticed funky "ghosting" on one of the flasher repeater circuits when I used LEDs for those... Someone figured out why on an old thread, I think...
Yeh, I thought I'd prefer the bright white and fitted them first. They were novel for a very short while. I tried hard to like them - but classic suits the car much better.
Strikingly better illumination though; very even - and much brighter.
I still want to add a proper LED dimmer so I can turn them down until they're like watch dials (for unlit roads), but the "sort of" dimming that LEDs give on the stock rheostat (until they cut out completely at ~60% or so of "full bright" as they drop out of their operating voltage) will do for now.
'77 S with '78 930 power and a few other things.
Old 10-17-2018, 08:34 AM
Runnin on empty
acme911's Avatar
Spuggy
Regarding LED’s. Like you I tried out some of the first generation LED’s on my Dodge truck. Disappointed with problems, I chucked them.
The Festoons were purchased on Amazon...Zero problems.
As recommended by others, I did not replace my turn, generator and fuel reserve lamps. Carmagic’s Kit comes with the high beam, parking and one extra bulb. Very nice!
With my SpokeLED kit I added the LED specific flasher relay. This solves “ghosting” flashes. Prior to using Spokes system I tried LED bulb swaps. These required the use of load resistors and were better than incandescent, but still not anywhere near the amazing output of Spokes!
My take away from swapping over to LED’s is that the latest generation of lights have solved a lot of the earlier glitches.
Old 10-17-2018, 09:46 AM
