Hbrand
hbrand's Avatar
915 Transmission shift 3-4-5 problem
The shifter in my 1978 Porsche 911 has no resistance going to 3-4 -5th gear.
1-2 gear is spring loaded to the left, but when I go for 3rd gear I easily end up in 5th gear with zero spring load.
Is the problem the shifter or the transmission ??
I bought the car that way.
Thanks, and greetings,
Harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 10-25-2018, 02:03 PM
pete3799's Avatar
A stock shift lever is not spring loaded to the left. Only 5th and reverse are spring loaded.
You may have an aftermarket set up. Take a picture of it.
Pete
79 911SC RoW
Old 10-25-2018, 02:59 PM
Under the radar
Trackrash's Avatar
Could be shifter bushings, shift rod coupler, or the guide fork in the transmission came loose.
Pull up the shift boot and take a picture so we know what shifter you have.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-25-2018, 03:42 PM
I’ll put the money on the guide fork on the inspection plate
If that’s the fault replace the whole plate and fork, don’t try to fix it
Bruce
Old 10-25-2018, 03:47 PM
Hbrand
hbrand's Avatar
Murphy's Law wins again
Part 3 in the drawing is installed upside down. This puts the shifter spring loaded to the left side.
What a crappy thing to do.
Greetings, and thanks
Cheers
1969 Mercedes 280SL
Old 10-26-2018, 07:25 AM
Hbrand
hbrand's Avatar
more shifter woes
Turning part 3 around would also not work.
The shift fork is for a standard shifter while all other parts are
from a short shift kit.
So need a short shifter shift fork. WOW
Cheers
1969 Mercedes 280SL
Old 10-26-2018, 11:52 AM
There's no indication in your text you have a 930 gearbox, yet that illustration shows a 930 shift housing.
An early SC 915 shift housing illustration follows:
Not sure why your factory stock 915 shift lever has spring tension on the 1/2 side. Typically, only on 5th/Rev. AFAIK, a 930 4-speed turbo shifter doesn't have any springs
The issue may be due to a worn front shift shaft bushing (item 22 above). Excess play here prevents the lever from selecting the proper gears.
Sherwood
Old 10-26-2018, 04:03 PM
