-   -   x-Faktory: Carrera backdate in the queue (http://forums.pelicanparts.com/porsche-911-technical-forum/1012179-x-faktory-carrera-backdate-queue.html)
frankoporsche 04-17-2019 02:34 PM
Hi Al
I really need your help ...so please PM when you are free.
al lkosmal 04-22-2019 10:14 PM
progress
I expect that the 3.5 will be completed this week and on the test stand shortly.....also, nice contrast between an original, stock 2.2 w/Zeniths and the 3.5 with PMO/EFI/ITBs....very different, but I like the way that the EFI still captures the old school independent throttle body vibe ....but combines it with new-school engine management......different strokes, both cool.
http://forums.pelicanparts.com/uploa...1555999943.jpg
http://forums.pelicanparts.com/uploa...1555999943.JPG
regards,
al
Robbyhighlife 04-24-2019 04:51 AM
Exciting build! Looking good!!
al lkosmal 04-24-2019 08:24 AM
thx..more progress
Making a bit more progress on the 3.5...starting to shape up.http://forums.pelicanparts.com/uploa...1556122996.jpg
Litle brother 04-25-2019 04:30 PM
Looking forward to see the power result on the 3.5 engine.
Great work Al. [emoji106]
onboost 04-25-2019 08:28 PM
Some nice goodies there Al.. excellent build thus far!
al lkosmal 04-28-2019 09:59 AM
Should put down some decent power....but this one won't likely hit the dyno prior to delivery to my customer Raz....who is located in Kuwait........
Shaun @ Tru6 04-28-2019 11:18 AM
Great work as always Al. Does the 3.5 build use separate air cleaners or does a plenum go between the two sets of stacks? Is there a benefit to either method of drawing air into the horns?
al lkosmal 04-28-2019 05:48 PM
Shaun,
although I have been reading up a bit on using common plenums with ITBs, with the reported benefits being improved power in the mid-range/high RPM...eliminating any flat spots.......but I have not tried this approach yet so I cannot provide any firsthand experience or back-to-back comparisons.....but the ITBs themselves, with individual filters or rainhats (PMO) are such an improvement over the factory CIS or 3.2/3.6 MAF throttle bodies with common plenum...I have been very happy with the results and the beauty of modern engine management is that you can really tune out the flat spots. I've seen some of the stuff that Rothsport is doing with variable plenums etc and it is impressive and brings more power.... I am always open to new ideas and more power.....up to a certain point where I start to think that it is too complex or doesn't meet my price/performance criteria for street driven canyon carvers (which varies daily)
I do like the direct path and equal air intake that you can achieve with ITBs. Seems to work very well.
regards,
al
speednme1 04-29-2019 01:06 AM
I thought a tune on the dyno is a must when using EFI unless the EFI is plug and play. Is this the case here?
Shaun @ Tru6 04-29-2019 02:29 AM
Thanks Al, interesting stuff for sure.
blee 04-29-2019 06:59 AM
Nice progress Al! Nice to have a client with an open mind. ;)
Wow, I didn't know that Rich spoke French.
Do tell us more about the cafe racer...
al lkosmal 04-30-2019 06:16 PM
I have installed many...many EFI systems and I have never been to a dyno. I do all of my testing and tuning on the road, in real driving conditions.....drive, datalog, review ,revise, drive, datalog,review,revise...rinse & repeat until awesome. Quite a few of my customers have had additional dyno tuning done and I've seen excellent results...I've also had others come to me after dyno tuning to refine the tune....etc. i.E. I think that they both work well, if the person reviewing the data and revising the tuning is experienced..that is likely the biggest variable to good tuning.
al lkosmal 04-30-2019 06:22 PM
almost there.....
I will be loading this monster onto the test stand tomorrow and firing up before the week is out (assuming my crank pulley shows up)..........stay tuned...
http://forums.pelicanparts.com/uploa...1556677147.jpg
regards,
al
digitaldgp 05-01-2019 05:50 AM
Looking Great Al!! Cant wait to see the video of it running.
al lkosmal 05-09-2019 04:27 PM
pending garage fire........
One step closer to the danger zone.
I've been waiting for the correct crank pulley for the 3.5 motor and it was delivered today...finally. I have the engine mounted on my test stand, fuel is plumbed, fuel pressure is good. The AEM Infinity is all wired up and ready to go......very quickly communicated with my laptop. I need to install a fan belt and the MAP hoses....add oil and....let there be fire!!!!
Here is the engine test queue....the engine in the background is a nice, rebuilt 2.2T motor.....I'm currently waiting for parts to complete the rebuild of the Zeniths, but in the meantime I have some of my RHD ITBs sitting on it....once tested, etc...it wll be for sale.
http://forums.pelicanparts.com/uploa...1557448009.jpg
stay tuned
al
al lkosmal 05-23-2019 06:01 PM
The 3.5 is alive.......
After some ignition synch debugging it fired right up. It is not tuned yet, just running on my start-up file....rings not seated, etc.....but it is running pretty good right from the 1st start........tomorrow I'll run it in and start the tuning.......Oh yes!
https://www.youtube.com/watch?v=_t_wd-tbFQ0
OldRacerP 05-23-2019 06:21 PM
I think I got mechanically aroused. Thank you!
Rich Lambert 05-23-2019 07:17 PM
Looking good Al!
al lkosmal 05-24-2019 10:57 AM
rev it up!!!
After running in the 3.5 engine and a little tuning it is running and revving nicely....the crappy mic on my camera does not do the sound justice.....it sounds awesome
https://www.youtube.com/watch?v=jul062yL-U4&feature=youtu.be
PS: oldracer for the kind words.
PSS: Rich, I couldn't wait to get back from Treffen to fire this up......
