-   -   x-Faktory: Carrera backdate in the queue (http://forums.pelicanparts.com/porsche-911-technical-forum/1012179-x-faktory-carrera-backdate-queue.html)
sp_cs 05-24-2019 12:14 PM
Originally Posted by Shaun @ Tru6 (Post 10441582)
Great work as always Al. Does the 3.5 build use separate air cleaners or does a plenum go between the two sets of stacks? Is there a benefit to either method of drawing air into the horns?
This is my plot, pretty much back to back, with plenum plotted in the thicker lines.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/907542-gt3-crank-3-2-3-4-a-3.html#post10373597
al lkosmal 05-24-2019 01:21 PM
sp_cs...thanks for the link to the plenum/stack dyno plot...very interesting.
Shaun @ Tru6 05-24-2019 02:27 PM
Thank you! As Al says, very interesting indeed. I'll have to go through your whole thread.
Did you drive both set-ups or just dyno? If you did drive them both, any thoughts on character of each?
RSBob 05-24-2019 08:37 PM
Ahem..... not to belabor the subject of the thread but... not that I am inpatient however we might need a Mrs Jeff intervention.
al lkosmal 05-24-2019 09:12 PM
rick, i would look forward to that!!!
sp_cs 05-24-2019 09:56 PM
Unfortunately not - it was setup with common plenum on the lower comp pistons, then changed to stacks on high comp pistons and twins plug.
I can say the second phase which also added the Eisenmann made a marked difference above 4k, it hits the limiter with ease.
Below 4k it doesn’t feel that much different at all to the plenum and lower comp piston setup. The plenum gave it a GT3 style howl, however there is more of a roar with the stacks and ITG filters.
Shaun @ Tru6 05-25-2019 03:00 AM
Thanks Shirish, good to know.
al lkosmal 05-30-2019 08:35 AM
leak-down......
This engine turned out right......after tuning on the test stand, I did a leak-down test.....and I've only seen results this good once before, so these are better than could be hoped for. (keep in mind that the accuracy of the test equipment is +/- 2%....but still great results)
http://forums.pelicanparts.com/uploa...1559233423.jpg
Also, for the last 2 years or so, I've been using the engine sealing kit sold by Henry at SuperTech (available through Pelican) and I have to say that I recommend the kit and method highly.
Now, i'm installing the Rasant wiring harness and once the tranny has some work done, it will all be installed back into the Carrera.........getting a little closer.
regards,
al
RSBob 05-30-2019 11:43 AM
Originally Posted by madcorgi (Post 10307003)
Or I suppose x-factory could mean that those who spend too much money on your products have ex-wives?
Too funny. Since I am on my 3rd, you may be onto something. Al, looks look like credit and reimbursement of attorneys fees is waaaay over due.
al lkosmal 05-30-2019 11:49 AM
rick....I give you all the credit in the world.....for amassing the attorney's fees....
al lkosmal 06-18-2019 09:40 PM
it is in there!
Pivotal moment....the 3.5 has landed...I'm doing the electrical and fuel plumbing....I expect to fire this up before the week is out...and maybe it will move under its own power for the first time in awhile......http://forums.pelicanparts.com/uploa...1560922793.JPG
al lkosmal 06-24-2019 09:27 PM
fire!!!!
It is alive......
https://www.youtube.com/watch?v=e5_xXcJYXVc
I will install the WEVO stuff and the GTS seats and then.....let the road tuning begin....
regards,
al
Bigtoe32067 06-24-2019 10:30 PM
Al
Forgive me if this has already been covered but is there a reason it's using PMO ITB's and Rasant and not your ITB's and MS?
I am about to start on a 2.8 ITB COP possibly MS3x and have been to your website frequently and am planning to contact you as soon for some much needed advice, direction, moral support...
Tony Moore
al lkosmal 06-25-2019 10:12 AM
it's all good
Originally Posted by Bigtoe32067 (Post 10502550)
Al
Tony Moore
tony,
Greetings and thanks for the interest.
I can provide Megasquirt, AEM, Electromotive, Motec controllers, etc.
I can provide RHD, PMO, Jenvey, TWM/Borla or ATPower ITBs
I can provide custom-made or off the shelf wiring harnesses, etc.....
and it is all very good stuff...........
My intention is to make available a range of systems and technical support that provide the Features/Price/Performance required or desired by the end user.
I'll be glad to work with you to meet your project goals too!
regards,
al
1980 SC Targa 06-25-2019 01:11 PM
Looking forward to seeing this one come to life! Great work!
Bigtoe32067 06-25-2019 01:43 PM
Al
Thanks for the response and that sounds awesome. I'll be in touch hopefully soon.
Tony
frankoporsche 06-25-2019 04:44 PM
Originally Posted by al lkosmal (Post 10502526)
It is alive......
regards,
al
Hey Al
I just receive my wires Harness back from Rasant with the jumper wire today...
btw I am jealous the motor sound really nice..
al lkosmal 06-25-2019 09:32 PM
Originally Posted by frankoporsche (Post 10503455)
Hey Al
thx....It does sound great, but my camera mic does not capture the sound very well...it is much deeper....
regards,
al
al lkosmal 07-18-2019 09:22 PM
tuning time
The Carrera backdate is a driver....tuning is underway and a few details to complete, then it is off to Kuwait for final bodywork, painting and extra design touches by the owner....Raz!
http://forums.pelicanparts.com/uploa...1563513505.JPG
regards,
al
Note: flag mirrors will be removed, holes welded and mirrors replaced with these.......
http://forums.pelicanparts.com/uploa...1563513647.jpg
Macroni 07-19-2019 03:25 AM
Love the mirror.... what are they?
