Ignition start on a cold engine
1987 Porsche carrera...recently when I turn the ignition key, the engine fires right away BUT it sounds like on a 5 cylinders FOR ABOUT 1-2 SECONDS and then reverts to normal. once driving and restarting, it starts normally and right away...
It is not a big issue...just wondering why???
Old 11-05-2018, 07:10 AM
old man neri's Avatar
Something is probably slightly out of tune/not working right. Could be an older plug wire, could be a distributor, could be an injector, could be the base idle mixture not set right anymore could be....blah blah blah.
In essence, not only is it a 30 year old car but it is a 30 year old design as well.
If you want, post a vid. Maybe someone can be more precise with what the issue could be.
Old 11-05-2018, 07:59 AM
^ +1 on the above. If those items haven't been serviced in a long time then that's probably it.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 11-05-2018, 08:10 AM
David,
How long has it been since the plugs, cap, rotor, and plug wires were replaced?
Ever had the injectors cleaned?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-05-2018, 08:47 AM
kent olsen's Avatar
If you jump in and turn the key right away it may be you just need to wait a sec for the fuel pump to build equal press to all injectors. If not Steve's idea would be my next step.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 11-05-2018, 09:10 AM
Makes no difference, the fuel pump does not run till the DME sees pulses
from the flywheel sensors.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 11-05-2018, 10:19 AM
kent olsen's Avatar
Shows you what a weber guy knows.
Hi Steve
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 11-05-2018, 10:22 AM
cold start
The wires, cap and rotor were replaced about 4 years ago...
recently The wire cap on one of the cylinders popped out and I tightened the wire cap connection to the spark plug...it is not popping anymore but may be the reason.
The injectors are part of Sal Carceller MAF kit that was installed June 2017 (amazing kit)
and my top end was overhauled last year, as well. Car never ran as well as it runs now...I will wait a few seconds, as suggested, to allow fuel pressure buildup and report.
Old 11-05-2018, 11:33 AM
Hi Steve
LOL,..Hi Kent!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-05-2018, 11:35 AM
How many miles have you driven in the past 4 years?
I would consider replacing that plug connector.
Make sure the fuel pump check valve is working correctly.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-05-2018, 11:37 AM
cols start
I drove approx 20,000 miles...
Where is the fuel pump check valve in an 87 carrera?
can you replace one wire only from a set?
I did try to start the car after waiting for 2-3 seconds with the ignition key on...same result. but shutting it and re turning the key it was perfect...very strange....
Old 11-05-2018, 12:00 PM
On a more modern car that will make a difference as it allows the fuel pump to prime. On yours it will make no difference as the fuel pump does not prime.
I wouldn't go too far trying to fix things that may not be broken. My 88 does sound a little rough for a second or two when starting from cold. Post a vid to see what we are talking about.
Old 11-05-2018, 01:11 PM
cold start
Thanks all for the responses...
I put TECHRON full system solution and guess what...issue was resolved!
Old 11-06-2018, 10:19 AM
scarceller's Avatar
Guys for the record: David runs my custom MAF system and with this system if you turn key to RUN it primes the fuel pump for 3 seconds. You will actually hear the pump run for 3 seconds. I highly suggest that prior to STARTING you move the key to RUN and allow the pump to prime then proceed to START. The feature that primes the pump is unique to my MAF setup and is not the way the stock system works, stock system never primes pump prior to START.
If the car sat for a few weeks with E10 fuel in the tank and the tank was not full it's possible the ethanol separated from the fuel and gathered up some water moister and sat at the bottom of the tank. If this were to occur you would run lean at startup till that fuel at the bottom of tank was used up or till you agitated the fuel in that tank by driving.
So how long has the car sat? And more important was the tank low on fuel, below 1/2 tank? And do you use E10 fuel?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-07-2018, 10:54 AM
Sal,
I agree that the three second pre-prime is a great idea to include in your system, but for us folks that can't quite afford your complete system as of yet, there is a solution. Focus9 Technology offers a solid state DME relay that includes the three second pre-prime feature. I have used one for the last two years and it operates perfectly.
911 Solid-State Relay (Pump-Prime) — Focus 9 Technology, LLC
Old 11-07-2018, 12:20 PM
scarceller's Avatar
So long as the relay you mention works well and has the added bonus feature for 3 second prime that's a nice option.
Also keep in mind that if the engine dies for any reason (especially in a car crash) the DME will always deactivate the relay. This is so the fuel pump shuts down in the event of a car crash. You need to be certain this solid state relay honors this behavior ALL the time. I'm sure it does but it's worth asking.
Originally Posted by uwanna View Post
Sal,
Sal
1964 356SC (SOLD)
Old 11-07-2018, 01:02 PM
ignition start on a cold engine
I re read my own thread because the issue originally posted is back...and only on a cold start. I did try using the suggested 3 seconds priming of the pump ...no luck...
I do have Sal's MAF kit and I also have the focus 9 DME relay...
Steve@rennsport did suggest to check the fuel pump check valve and so did my long time mechanic...but since my car is 32 years old and I do have a brand new fuel pump that has the check valve on it, I will replace the pump some times this winter.
Old 01-03-2020, 07:24 PM
