MichiganMat's Avatar
Send a message via AIM to MichiganMat
Installing a WaveTrac, are the stock ring bolts long enough?
Im installing a WaveTrac into my 915 box. The flange is much thicker on the WaveTrac than it is on the stock diff and Im concerned there isn't enough meat on the threads of the ring bolts to use them.
Do longer bolts exist?
Whats is the suggested way to install this differential?
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 11-05-2018, 06:11 PM
disband
juanbenae's Avatar
PM me your number, lost it like three phones ago... you still close by me? invite me over for a beer, a tour of the shop and ill introduce you to the domino....
Old 11-05-2018, 07:27 PM
Harpo's Avatar
The short answer is that you should have the same amount of threaded engagement as before. The longer answer depends on the grade of your bolt. Hopefully is a 10.9 where you should have about 1.1 diameters of threaded engagement.
Hope that helps
Old 11-06-2018, 03:22 AM
gearhead
The original LSDs had a thicker flange as well and longer bolts. You need the LSD version.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-06-2018, 05:31 AM
Gas Huffer
MichiganMike's Avatar
Makes sense to me, Matt M - Much thanks as always for your vast knowledge!!! (also thanks for the tip on the 5th gear, ended up getting one)
~Mike and Mat
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi
69 Porsche 911T - Project
04 Ford F-150 FX4 - Boris
Old 11-06-2018, 12:15 PM
