Red Line Service
Airbox & proper tuning
Just a Red Line endurance test. Today we're tearing down an 83 911SC engine for a refresh. This car has 206,000 miles on it, and has been PROPERLY serviced since day one. Guess what, ORIGINAL AIRBOX! That's right, blue inspection decal, dated 1983, etc. So remember, proper tuning, valve adjustments every 15,000, NO pop-off valve.
Just thought you guys should know!
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Same camp here as well; seems like the pop off valves can cause as many problems as they solve and a big backfire will blow the box anyways.
Keep it tuned!
Rutager West 1977 911S Targa Chocolate Brown |
I hate to be that guy but I bet it leaks - the glue goes bad around the seam seals just from age. Dunk it in a bucket of water and see. I'm not a pop off guy either.
Functionista
Yep we’ve seen a few high milers as well with no pop off. Can’t throw a band aid on a major tuning problem....
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
And let me guess, standard paper air filter too?
Red Line Service
Yes Peter. Quite a few of them by now! Mahle air filters, Mahle fuel filters, and Mahle oil filters. Our filter of choice.
I had a frustrating no start issue after I adjusted the valves and it turned out to be the entire pop off valve had blown out of its mount. I vaguely recalled a very minor backfire when I first cranked it after the valve adjustment and oil change. I epoxied it back in and it started right up. It runs great 5 years later.
