Exclamation Test fitment of newly refinished Fuchs. They fit......kind of?
It was in the 50's today and I finally got a chance to take my car off the jackstands it's been on since November. On top of a complete overhaul to turbo brakes, I have refinshed and mounted 8x16 (951) fuchs in front and 9x16's in the rear with 225 and 245 tires. The rears have plenty of room and are no problem. The fronts are very close to the inner fender lip. On the trip to the shop, they rubbed once over a bump on the right side. I had the guys at the shop check out the camber and they said I am about at my limit. I personally think I could go more (I'm at 1 1/2 degree's right know). These guy don't like to jack up the camber on street cars if possible. I have WAY to much time in these to drop back to 7's, so I'm considering a few options. The rubbing is minimal and in fact the left side doesn't touch at all. My lips are not rolled either but sort of pushed in a bit. I would thing my options would be to:
1. Add at much neg camber to the fronts as possible.
2. Completely roll the lips. My brothers car shop actually snipped a major portion of the inner lip away and then gently pinched the metal to create maximum clearance.
3. Machine the inner wheel surface? May sound crazy but these wheels seem to have extra offset compared to 6's and 7's.
4. Find the person who said the 8x16's (951) bolt right onto Carrera's and pistol whip them
5.???
Heres some pics.
Old 03-08-2003, 11:53 AM
Cornpanzer's Avatar
Cant help you with your problem, but it sure does look nice. The polished and paint detailed fuchs give it some pop without looking gaudy!
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 03-08-2003, 12:05 PM
MBruns for President
JeremyD's Avatar
I too have a set of 951 8 x 16 on the way. Are these Porsche Part # 951 362 117 00?? Pre 1986 944 turbo offset?
I think the thread I saw did say that the fronts needed to have the lip rolled... I am prepared to do this. Is yours done?
Same ball game as you - Your just two to three weeks ahead of me. BTW what tires did you mount?
Old 03-08-2003, 12:53 PM
CarreraCab's Avatar
89911, very good looking car, set off nicely with the polished Fuchs. I would not machine anything off the rims, but possibly try a smaller tire size for the fronts. I could not make out the Brand you are running on your car but some manufacturers make a 215/45 or 50 series that might help, check Tire Rack for Brand/availability. I wussed out on my fronts and stayed with the 7" Fuchs, and still could not get a 225 to clear at the ride height I like. Best of luck, Doug
Old 03-08-2003, 12:58 PM
JeremyD's Avatar
This guy got 8 & 9's working on an SC 225's up front... 8 & 9 inch wheels for SC
Old 03-08-2003, 01:03 PM
beamonk's Avatar
Send a message via AIM to beamonk
You may be a little too low in the front. Mine scraped until I raised it up a tad
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 03-08-2003, 03:12 PM
Thanks so far. My car is very low. I run 225/45/17's with 8" Fikses all day at the track with no problems. I think the fuchs offsets are still a tad more to the outer wheel well also. These are the 944 turbo fuchs also. I did not go into this blindly and in fact, the guy at Ernie's alloys did not promise me they would fit without some possible modifications. We 911 guys always have to make things harder on ourselves to get that 1/10%! As far as a smaller tire, the 205's are way too small for this rim and as far as 215, I don't think they come in too many brands. The tires on the car are brand new S03's 225/50 and 245/45. One more reason not to change anything. As I said before, changing these tires/rim is not an option! My hands have just recently recovered from the work it took to finish these and the thought of doing a set of 7's makes my knuckles ache. Just one more word, (make that two). Al Reed.
Old 03-08-2003, 03:28 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
FWIW, different brands of tires in the same size can make a significant difference, I think that S-03s are about the worst, (for clearance). Sorry.
Signed, speeder(at Kevin's shop)
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 03-08-2003, 05:15 PM
Bill Verburg's Avatar
I see 2 possible steps that you can take
  • totally shave the lips, but I don't think that will solve the problem
  • use 225/45x16 SO-3s. They have a radius of 23.9", .5" shorter than the 225/50. This will drop the front end a bit less than .5" and give you ~.5" more room at the lip
The pictures may be deceiving but it appears that a bit more droop in the front would be a good thing
I have had tires as short as 23.1" on the front of my Carrera. they work great.
Bill Verburg
Old 03-08-2003, 05:50 PM
From the way it looks, a little negative camber, both front and back wouldn't hurt.
Old 03-08-2003, 05:52 PM
Thats my thoughts also. What is the most you can get out the front end? My car has the monoball strut mounts and can gain additional neg camber.
Old 03-08-2003, 06:04 PM
KTL KTL is online now
Schleprock
KTL's Avatar
I'd have to second the recommendation of the lip shaving/rolling.
Too much neg camber is going to eat your tires in a hurry.
Even though you don't want to hear it Michael, the 225/45 idea recommended by Bill V sounds like an excellent idea as well. The ride will be a tad firmer with the 45 and the steering response will probably be a bit better as well.
Kevin L
'86 Carrera "Larry"
Old 03-08-2003, 06:41 PM
Bill, thanks for the advice. I am puzzled myself why I didn't go the 225/45 route. I guess all the information I could gather kept recommending 225/50. Oh well, any advice if TireRack will take back a set of tires that have been mounted and have about 10 miles on them? If not anyone looking for a set? I'll let you know how it works out.
Old 03-08-2003, 09:23 PM
PRO Motorsports
Tyson Schmidt's Avatar
Michael, I'd recommend that you run 2 degrees negative up front and 2.5 neg. in the rear. I know you track the car a lot, so I think this is an appropriate recommendation for you.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-08-2003, 10:12 PM
Irrationally exuberant
ChrisBennet's Avatar
I have these tire in that size and the 245/45's have the same (measured) treadwidth as the 225/50's. Have you noticed this on yours?
-Chris
Old 03-09-2003, 04:55 AM
Chris, I did notice that the 245's on the rear look a bit stretched on the 9" rim. A 255 or 265 would fit the rim and wheel well better. Tyson, as far as the camber, I trailer my car but do take it occasionally on some longer rides. While 1-1.5 neg camber doesn't deteriorate the handling too much, will 2-2.5 cause excessive dartiness on straitline runs? If not too bad, I'll go that route.
Old 03-09-2003, 05:04 AM
If you are planning on tracking the car, you will definitely have to roll the fenders imho. If it rubs on the street it will amplify on the track. I am running 9's (245's) in the rear and 7's (205's) on the front with Yokahama advans. They really turn in well and stick like glue.
DC
83 SC - track car
1973 RSR 3. something Twin Plug race car
1988 944 Turbo
Old 03-09-2003, 05:51 AM
Just a thought, my car is pretty low and I'm running 225-50's on 7's up front (Bstone RE-730's street, Khumo Victoracers track). Fender lips are rolled flat. My wrench did it with a ball pean hammer. Before he started he said "you may not want to watch this". No paint cracking and no rubbing (fender lip sits at about 24.6"). He's done more than a few of these.
I agree, 245's on my rear 9's look a bit stretched...especially compared to the 225's on 7's up front. Roll the lips and get your front above 24.5" and you should be fine.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 03-09-2003, 06:21 AM
Thanks so far. I guess I should wait and try the lip rolling, camber and see if that doesn't correct it before buying 225/45's. As far as lip rolling, as I said before, I run 225's on Fikses for 3 years using track tires (R1's and Victoracers) without any rubbing. And track tires are generally square and have a wider treadpath then the street tires. As far as ride height, the picture shows the left side. The height looks good here. When I had the car corner balanced, the R-L heights are not exactly equal and I suspect the right side is a bit lower. I'll have them raise it a few millimeters. What is TireRacks policy on mounted, slighty driven tires? I once returned track tires that they told would fit and the rubbed. They took them back. I generally buy 2-3 sets a year of them.
Old 03-09-2003, 08:40 AM
