Spring plate trailing arm question
Hello Gentlemen,
Was just wondering if it is possible to replace the Spring plate bushings on a 1972 911 T without removing the trailing arm? Thank you, Chris |
Spring plate bushing removal......
Chris, All you need is to remove the sway bar if you have one and loosen the spring plates bolts. The spring plates are bolted to the trailing arm/s and the other end at body with 4 bolts. If the spring plate is not stuck to the torsion bar, removal will be easy and simple. You will know when you get to this point. Keep us posted. Tony |
Thank you Tony!
Under the radar
I might be confused about your original question, but if you plan on only replacing the outer spring plate bush you only need to remove the spring plate cover. Otherwise you have to remove the spring plate from the car which will require it to be unbolted from the trailing arm. Be careful as there is tension on the spring plate from the torsion bar and you may need to use a floor jack under the spring plate.
Then after re-assembly you will need to make sure the angle of the spring plate is the same as it was originally. You can mark or measure the angle before removal. Then an alignment should be performed.
^^^^^ What Gordon said. In addition, I wouldn't replace the outer bushing only. I'd only do it by replacing the bushings on both sides which would entail everything Gordon mentioned.
Marv Evans '69 911E |
Thanks guys I plan on replacing both inner and outer. I just wanted to know if I could unbolt the spring plate from the trailing arms and remove it from the car without removing the entire trailing arm first.
Thank you for the advise with the angle of the plate and the tension from the torsion bar. |
Chris. I'm not a mechanic, but I've done the rear suspension (and front) on my car three or four times. Practically speaking you need to separate the spring plate from the swing arm. The problem is trying to get the same angle of your spring plate as you have now - assuming that's what you want. Wrestling with the amount of mass trying to get the spring plate off the torsion bar and back on at the right angle isn't something I'd attempt. One thing I finally invested in (at Harbor Freight because I don't do it every day) is a digital clinometer. They are so much more accurate and easy to work with than the springy dial meters. As you get into the job, you'll see what has to be done. It's not exactly rocket science. It just mostly takes time and perseverance.
disband
great time to consider updating to a later adjustable spring plate if originality is not a huge factor. you can get a fare amount of height adjustment with them instead of having to hit the angle dead nuts on when reindexing.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
