Perpetual Reassembler
2jmotorsports's Avatar
External Thermostat Testing
Hello Pelicans,
I am currently rebuilding my external thermostat and wanted to run my test results by you.
1. Drop it in a pot of water. Notice the circular plunger is flush with the cylindrical end of the thermostat unit.
2. Bring it up to a boil.
3. Plunger goes up about .400 inches. Does this look like acceptable travel?
4. If you drop it in the housing, the plunger holds the unit up and exposes the slots through the port shown here. I am guessing in this condition oil is allowed to pass through the lines and front cooler.
Lastly the plunger stayed up after the unit cooled. I was able to push it back down with finger pressure. My guess is in the housing, while hot, the plunger will overcome the spring pressure to raise the unit, but once it cools down, the spring pressure will push the plunger back into the unit, lowering the unit and covering the slots, and prevent oil flow through the front cooler until the temp goes back up again.
So what do you guys think? Is this unit still good?
Thanks in advance.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 11-25-2018, 11:08 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil T-Stat.
What prompted the re-build?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-25-2018, 12:34 PM
Functionista
manbridge 74's Avatar
Been awhile since I pan tested one. How did it operate on the car? I like to use a infared gun to read temps.
One thing I recall doing on one that I noticed was sticking was polishing the plunger and bore where I saw some scuffing. No sticking on re-test. Not sure if yours is designed to come apart though. I seem to recall mine having a large circlip.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-25-2018, 12:58 PM
Gerry
Wrapping up a rebuild on a tired engine and rebuilding the oil cooling system to clean everything out.
Thermostat worked fine beforehand. Just testing as a sanity check while Im in there.
Old 11-25-2018, 04:48 PM
T77911S's Avatar
don't know the cost but why not just replace it and not worry.
any problems getting the hoses off the Tstat.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-26-2018, 03:57 AM
They are only about $30. If I bought a new one I would probably test it anyway to verify it is not a dud. Problem is no acceptable criteria are listed anywhere.
Thankfully no issues removing the hoses. Removed all the lines as a unit, lots of penetrating oil, heat, and wrench clearance to get them off with no damage to either the tstat housing or the lines.
Old 11-26-2018, 08:36 AM
