That vacuum hose that plugs into the back of the 3.2 airbox, what does it really do? Is it really a vacuum tube? I ask this because the airbox is not really a sealed unit with the open snorkel. I just wonder if that tube is for vapor rather than vacuum?
http://forums.pelicanparts.com/uploads20/911_motronic_vacuum12405899401333400906.jpg
Looks to be emissions related, goes back to the carbon canister in the right rear fender well. I found mine loose one time and had not noticed any impact on performance or idle.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
Burnin' Rubber
I have a similar modded box, I quite like the fact that it’s easier to clip and unclip the back like u mentioned. Bonus is the nice swooshing sound but it’s hard to hear with my Supercup exhaust |
Also, used air box, replete with trumpet, for sale... 3.2 Airbox
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
In our rear mounted engines, there is only cold air intake in the engine compartment when the ambient (outside) air temperature is "cold". IOW, at speed, the intake air temperature is pretty much ambient - whatever it is. If colder intake air is the objective, the vehicle must operate in a colder environment or the air must be treated to remove any latent heat (intercooler, water spray, etc.).
Cool intake air is more of an issue when the air source is typically exit air from a coolant radiator in front of the engine. Sherwood |
![]() Last edited by Satanas; 12-04-2018 at 12:05 PM.. |
Still here
Mighty Meatlocker Turbo
PS - it is impossible for that airhorn to have any positive effect on airflow (velocity, etc.) since it is placed prior to the air filter - if anything, it is a restriction. I will learn you a thing or two about a thing or three, yet, bro!!! Last edited by Rawknees'Turbo; 12-04-2018 at 09:04 PM.. |
Still here
That design detail isn't for noise suppression, is it ? Last edited by pmax; 12-05-2018 at 01:52 PM.. |
It was probably done that way for appearances - looks more race than if it was just a blunted tube, like a vacuum cleaner extension. Or perhaps the intake noise is actually reduced by the flared tip (just the!) - would be interesting to test that.
I suspect it's based on intake airflow design that's been around for a long time. The inlet curvature produces less turbulent air flow than a straight cut end. Not the same as a velocity stack with an uninterrupted air path to a plenum or cylinder. Any expected power increase by sexy-looking tubes and perceived pressure waves is negated by the presence of an air filter element between engine and outside air.
https://en.wikipedia.org/wiki/Velocity_stack IOW, looks and a bit of functionality. Sherwood |
Thread Tools | |
Rate This Thread | |
