Mounting rear sway bar- hints
Remounting the rear sway bars on my '72. Any tricks to getting the rear arm bushing on the ball mounted on the banana? Not much room to use a rubber mallet or bigger channel locks...
TIA
1971 914- original owner
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 11-29-2018, 12:59 PM
I would rather be driving
jpnovak's Avatar
I use a large C clamp across the trailing arm. YOu will need a block of wood on the backside to pull square. Takes a few minutes to crank it down.
I usually have the sway bar disconnected from the drop link.
Old 11-29-2018, 01:02 PM
Red Line Service
Marc Bixen's Avatar
Block of wood and a pry bar.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 11-29-2018, 01:31 PM
Check this out:
Post 110, if you have a cheap clamp for undoing the steering knuckles, it will work like magic!
That's it! my first 911 restoration thread- '72 911 S back from the grave (maybe)
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 11-29-2018, 02:09 PM
proporsche's Avatar
As Mark said no need any fancy tools, just use a pry bar...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-29-2018, 02:12 PM
clarkd's Avatar
I used a C clamp and a piece of scrap plastic lumber to prevent the clamp from slipping off.
Old 11-29-2018, 02:58 PM
disband
juanbenae's Avatar
I assume the other side is in place? you could try taking the wheel off and that might lighten the load on the trailing arm and get it closer. looks like the car is on a lift? when mine was like that it was on jackstands, both wheels off so I simply put a floor jack under the trailing arm on the other side, loaded it by jacking it up some and was able to tap in into the socket.
Old 11-29-2018, 03:01 PM
Tool worked great as suggested- popped on finally!!
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 12-01-2018, 12:12 PM
Works like magic! I was tired of bruising my knuckles and started looking around the workshop for what might work. I'm glad it was useful!
___oOo___
Old 12-01-2018, 02:38 PM
Also, heat the bushing up with a heat gun or hair driver. 10x easier when warm.
Old 12-02-2018, 11:36 AM
