Mounting rear sway bar- hints
Remounting the rear sway bars on my '72. Any tricks to getting the rear arm bushing on the ball mounted on the banana? Not much room to use a rubber mallet or bigger channel locks...
TIA
1971 914- original owner 1973 914 2.0 2018 911 carrera T 2016 981 Spyder PTS |
I would rather be driving
I use a large C clamp across the trailing arm. YOu will need a block of wood on the backside to pull square. Takes a few minutes to crank it down.
I usually have the sway bar disconnected from the drop link.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Red Line Service
Block of wood and a pry bar.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Check this out:
Post 110, if you have a cheap clamp for undoing the steering knuckles, it will work like magic! That's it! my first 911 restoration thread- '72 911 S back from the grave (maybe)
___oOo___ 1972 S 911 Targa kit http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html |
As Mark said no need any fancy tools, just use a pry bar...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I used a C clamp and a piece of scrap plastic lumber to prevent the clamp from slipping off.
disband
I assume the other side is in place? you could try taking the wheel off and that might lighten the load on the trailing arm and get it closer. looks like the car is on a lift? when mine was like that it was on jackstands, both wheels off so I simply put a floor jack under the trailing arm on the other side, loaded it by jacking it up some and was able to tap in into the socket.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
![]() ![]() Tool worked great as suggested- popped on finally!!
Works like magic! I was tired of bruising my knuckles and started looking around the workshop for what might work. I'm glad it was useful!
Also, heat the bushing up with a heat gun or hair driver. 10x easier when warm.
