911 car dies when Oil cap is removed
I just bought my 84 Carrera and wanted to check the oil level. I left in idle as manual instructs. Just as I remove the oil cap the car dies. I thought it was something else and tried again to confirm. Anyone know whats going on?
Mahalo
pkp
Old 08-06-2011, 10:13 AM
KNS KNS is offline
The idle should drop a little bit when the cap is removed, that's normal. Try bumping your idle up if it is already low.
Kurt
Old 08-06-2011, 10:31 AM
Assuming the restrictor is in place, the mixture might be too lean.
Old 08-06-2011, 11:15 AM
With the oil cap on and your car warmed up, what RPM is the car idling at?
'87 Carrera Cabriolet
Old 08-06-2011, 11:22 AM
steely's Avatar
You create a bit of a normal vacuum leak when you remove the oil cap - the car should be able to withstand this, and the rpm's will drop, but not to the point of stalling. If you already have a vacuum leak elsewhere, then the problem is compounded with the cap removal. The problem can be masked if you increase the idle, but the PO may have done this already.
Best thing to do would be to check for vac leaks for all of the lines to/from the air box, throttle body, carbon canister, fuel pressure regulator, fuel pres damper, cruise control, and brake booster. Also verify the intakes are tight - no leaks around the gaskets.
If you just got the car and this is happening, chances are it was neglected a little bit, and if you try to correct it, your car will love you for it. Do a search on this very topic and you'll get some more info. It really does help / albeit incrementally, to replace the rubber stuff. Good luck and hth.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-06-2011, 12:56 PM
There is a valve on the breather hose that is failing
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-06-2011, 03:35 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
If the check valve is failing, here are some pictures.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-06-2011, 03:49 PM
steely's Avatar
...or absent altogether. - Good point
Dan
Venetian Blue
Old 08-06-2011, 04:41 PM
Throw it on the ground!
The bulge in the breather host just to the left of the oil filler cap is where the oil restrictor is located is is a pic of the Porsche PN# 930.107.289.00
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 08-07-2011, 03:33 AM
Tori's Avatar
I know this is an old thread, but i came here looking for help to solve my same issue.
My scenario was a little different, freshened up motor reinstall and mine was doing this.
Turned out to be my breather restrictor was in the wrong hose. ( replaced my hoses )
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 12-01-2018, 05:37 PM
