Dear Friends
I wont to install a window roll up/down module on my 1983 911 targa I would like to the windows go down ( a little bit) when I open the door and for the window go up again when I close the door Does any only know a window module that do this job? I actually found one but my electrician told me that the window switch on the 911 rest on a positive wire and mostly of this module require a switch that rested on the negative wire Does this affirmation makes any sense? Is he correct? Thanks you all Ricardo |
Reiver
The later 911 (83 on up I believe) convertibles have this feature so it should be doable if you source/find the right door mechanisms.
De Oppresso Liber Strength and Honor 5th Legion |
