Help! CIS on a 74 2.7 - hose connection
Hi,
Can anyone please tell me where does the output of the part number 73 marked in red on the diagram attached, connects? Thanks in advance for any help. ![]()
K-Jetronic student ![]() |
Functionista
Nothing, when you look inside it is a dead end, sealed up.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
1974 and 75 don't use that hose connection, should be blocked as mentioned above
Many thanks guys!
Registered Minimalist
A picture for you
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Thanks Duane!
Thread Tools | |
Rate This Thread | |
