LinkBack | Thread Tools | Rate Thread |
Certified Pre-Owned
Uhhhh...I'm trying to post pictures of my clutch/flywheel etc. to get some opinions, but I can't get my images under the 64k limit. I've shrunk them to 649x480, but I'm still around 72k.
So how do you get your nice big pics posted??? Thanks- BG
'84 Carrera Coupe |
do a post multiple the size limit for that is 100K
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
isn't the limit 100k??
max |
Certified Pre-Owned
Thanks- I'll give that a whirl!
'84 Carrera Coupe |
Super Moderator
..or when you edit the pictures, look for a save or saveas option and reduce resolution down to about 75dpi
I like PaintShopPro for photo editing (mainly because I'm too cheap to buy photoshop) - you can get an eval version for free. It allows you to alter the size and compression ratio of the JPEG and tells you how big the resulting file will be. Might be something to consider.
Chris M 1985 911 Carrera w/ 3.6 |
nice doggie
I've always wanted to...
know how to do this...
Jerry 78 SC hotrod 02 Mini Cooper S |
Hetman, are you going to post four more pictures so we can see what your whole car looks like??
!! max
max |
You can safely use 50dpi for a computer image - this uses about half the size of a 72dpi picture. (dpi = dots per inch)
Rob McKibbon, Shuswap Boy <>< To steal ideas from one person is plagiarism, to steal ideas from many is research. Currently researching ideas for my '74 911 Cabriolet |
