15 inch tires
Anyone with any suggestions for where I can find a set of 15 inch "old school" looking tires?
![]() The rims are 15X7 with the same offset on all 4 |
https://www.google.com/search?client=firefox-b-1&biw=1600&bih=781&ei=bwkQXLyKCqLJ0PEPq6KIkAo&q=pelican+porsche+911+15+tire+site%3Aforums.pelica nparts.com&oq=pelican+porsche+911+15+tire+site%3Aforums.pelic anparts.com&gs_l=psy-ab.12...8125.9182..12844...0.0..0.75.215.3......0. ...1..gws-wiz.Hc4psipLFns
google is your friend. this has been discussed ad nauseam....
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
These are expensive, but they definitely look the business:
https://www.lucasclassictires.com/Porsche-911-Tires_c219.htm
78 911SC Targa, GP White |
Registered Minimalist
A lot of good options. An inexpensive and good looking tire is the dunlop direza They make a few sizes in 15X7 - a 205/50 or 205/55 or 195/60 would work for narrowbody midyear.
What year is the Targa? If it's an SC you have a lot more options. Tire rack is a great place to look.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
+1 Pirelli P6000
No physical quantity completely explains its own existence |
205/70R15 would have the correct 70's sidewall height and look more retro:
https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Defender+T%2BH&sidewall=Blackwall&partnum=07HR5DTH&tab=Sizes |
Vintage Owner
A friend just put Cooper tires on his 72 911 an$ is happy with them, though he doesn’t track the car.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
185/70 x15 is a 25.7" tall tire 3.2 Carrera uses 195/65 x15 on the same 6" wheels, these are 25.1" od tires, these can also be fitted to 7s the best match in od to the above 2 choices is the 205/60 x15 which is a 24.7" od tire and also works well on a 7 any other size is either too tall or too short
912 Geek
Check out BFG Comp Force T/A: inexpensive, long-lasting, and good (not great) on the track.
Odd that an '89 Carrera would have 7s all around, oe would have been 6 & 7 x15 w/ 195/65 & 215/60 tires these sizes could also be used w/ a 4x7 setup
The story is the guy took old narrow Porsche steel rims, cut the centers out and welded to some 7 inch wide rims from something else. To the best of my abilities they measure 15X7, 85mm centers, 4 3/4 inch backspacing, and either 3/4 or 3 1/4 inch offset (I'm not sure the correct way to measure offset?)
Spiderman
I currently run 225-50 ZR15 Toyo Proxes R888R on front and back on 7" and 8" Mahle rims and they look fine. These are my track tires. I got them this way from a forum member with RA1's years ago and he liked that he could rotate them front/back for wear. They look nice and fat and work great.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Is the wheel ET 23.2 like a 7" Fuchs would have? Here are some tall 15s to consider, you'll have to decide the stagger you want to use
Dump those heavy wheels and put 7 and 8” x16 Fuchs on - there I said it :-)
![]() Looking to do similar to the above. |
Yep I think I’m going with those same 185/70/15 Avon’s as well for my 73 hot rod. Currently running Dunlop 55’s and need a higher profile as my ride height is a bit too low and many early long hood friends are running the Avon’s as well.
1970 914-6 #2615 (Metallic Green) - SOLD 1974 911 US Carrera Coupe #63 (Lime Green) 1973 911 T Coupe #1891 (Gemini Blue) |
